Question about Carrier Heating & Cooling
How to esaliy Program the Tempurture on a carrier Thermostat
I have Carrier thermostat that we lost manual for. Model is 960-060170-30-R. We are trying to get the fan from permantly running to auto position. Any help would be great or a link to the manual
I believe that is the edge tstat and what Im finding is you can only control the fan when your not running a program. if you have occupied and unoccupied settings it may be under a business program rather than residential. Google the edge manual and follow steps to remove the programming. Good Luck!!
Jan 08, 2018 | Carrier Heating & Cooling
How to clear"service filter"after i changed the filter on Debonair 220 Carrier thermostat
Press mode and program together and hold to enter configuration. Press mode until option 11. 11 is the run time before reminder, put this to 0.
Aug 07, 2017 | Carrier Heating & Cooling
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ... > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
Tempurture gauge goes from normal to hot then back to normal replace thermostat already and still doing the same thing
-You could have an air pocket trapped in the engine. Look for an air bleed valve on or around the thermostat housing. Crack it open with engine running until only coolant, no air, is expelled. If none, take off the radiator cap (not while engine is hot, though) and run the engine until the thermostat opens and hot coolant begins circulating through the radiator. Shut off engine and put the cap back on. That should expel any air that was trapped. If it continues going hot and normal on the gauge, try replacing the temp sender unit. Also make sure coolant system is full, that includes the overflow tank.
Jun 29, 2015 | Cars & Trucks
How do I turn down thermostat on this water heater?
The temperture of a water heater should be approx 120 degrees. If you use a dishwasher that is the desirable tempurture to kill bacteria.
If your heater has two thermostates then make sure they are set for a 5 degree difference between them
Good Luck,
May 06, 2014 | Rinnai Water Heaters
How to program my air conditioner thermostat
Is there a model number on the control? I see it is a Carrier but we will need to track down an owners manual on line to figure this out. Visit my website and leave me some more information so I can help you.
Jul 11, 2013 | Heating & Cooling
I ned the thermostat manual or at least a HOW to program it. I have a 48 GS 10 seer 80 AFUE gas package unit with Carrier digital thermostat TSTATCCNAC01-B if their are additional manuals on the unit... has the books look for the 48GS060 not the GX model thes units replced the SS and SX models in 97also the t-stats will be in accessories
Mar 05, 2011 | Heating & Cooling
Help please. We lost instruction manual for our Carrier programmable thermostat. Not even sure what model but looks like a EDGE TP-PRH01-A. It says "Check Filter".
check filter is a setpoint left in the program of the thermostat it does not effect the thermostat peformance check carriers web site or google that number may come up but that reminder does not effect the function .
Aug 20, 2010 | Carrier TSTATHCP Programmable Thermostat...
Install programmable Carrier thermostat
you'll be needing an assistance from an A/C technician, If this a progammable you want, some configuration need to be done and a technician can only do that.
You can search the web for a local carrier dealer nearest to you
Nov 05, 2009 | Carrier Heating & Cooling
Carrier Infinity Control Programming Issue
Open the flap, and press and hold the advanced button for 10 sec. you will be in the Installer setup screen. scroll down to the setup subfolder and select thermostat and it will be in there.
Feb 27, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
35 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
