Question about Sony Televison & Video
I have a Sony Bravia KDL-40S3000 with a perfect picture on the bottom 3/4 and all messed up on the top 1/4. Could this be a bad tcom?
mistersony
  • 320 Answers
SOURCE: green pixel lines
It sounds like a bad LCD panel but you would have to post a picture of the problem for me to be sure
Posted on Oct 18, 2008
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
  • 532 Answers
SOURCE: My Sony Bravia has no colour
If the picture has no color or appear as black and white only, please reset the picture setting. To reset picture setting please follow the items below:
  1. Press MENU button on your remote.
  2. Press arrowtb.png to select setting.jpgSettings, then press ok.png.
  3. Press arrowtb.png to select picturemenu.jpgPicture Menu, then press ok.png.
  4. Press arrowtb.png to select Reset, then press ok.png to reset all the Picture Settings except Picture Mode and Display Mode to the factory settings.
If this does not not work, then change the picture board in your TV.
Please rate my solution.
Good luck.
Posted on Jun 27, 2010
Testimonial: "have colour now when I use my DVD player. but not with my Bell Express Vu PVR. I guess maybe I need a new receiver?"
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
How to change from ntsc to pal on bravia kdl-40s3000 40 "
Changing this requires a change of the tuner. There is nothing inside the set that can make this change. There are external systems that can do this, but they are expensive (multiple $100s).
Bottom line is that this would require a change in the internals of the set.
Hope this helps.
Dan
Mar 16, 2009 | Sony KDL-40S3000 40 in. LCD HDTV
Sony Bravia TV KDL-V32XBR1 picture
Try different cable, if you still get the problem after replacing cables, then you have a defective sygnal board (input board).
Dec 13, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony Bravia KDL 40S20L1
You should have a 1 year warranty from Sony. Call them before it expires. This is probably a LCD panel issue.
Oct 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Green pixel lines
Sep 11, 2008 | Sony BRAVIA KDL-40V3000 Television
Kdl-40s3000 hdmi settings
JUNH-THE HDMI CONNECTIONS ARE VERY FRAGILE I'D RECOMMEND SUPPORTING THEM ANY WAY YOU CAN.THE HDMI INPUT ON TV IS POSSIBLY DAMAGED BY NOW AND MAY NEED REPLACING.JOE TV
Nov 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
