Question about Coffee Makers & Espresso Machines
Will not work when I press down container - Coffee Makers & Espresso Machines
Hi, my tchibo coffee machine display is showing bean container empty when the container is full of coffee beans.I have removed the container and made sure it is there is nothing obstructing the tube.i have...
Hello
Push "Off" on the coffee maker's control panel. Unplug the coffee maker, and allow the machine to cool down completely. Remove the coffee bean container by lifting up on it and sliding it out. Wipe it out daily with a damp cloth, and slide it back into the coffee maker. Press down on the handle to click the container into place.
Dump out the water in the water container,Wipe out the water container with a damp cloth. Refill the water container with clear drinking water.
Remove the dump box and drip tray, and empty them.Wipe each one down with a damp cloth. Open the service door and push "Press." Remove the brew group by its handle, and rinse if off in a sink with hot water. Use the key provided to unscrew the plastic pin holding the metal filters together. Rinse each one separately. Put the filter back together and dry the separate parts with a towel.
Mix a package of descaler with the water in the water container every four to six months to rid the coffee machine of mineral deposits. Plug in the coffee machine, and select "On." Select the "Hot Water" button, and position the steam valve over the drip tray. Dispense two thirds of the descaler and water into a container in 15 minute intervals by turning the steam valve counterclockwise to dispense and clockwise to shut off the flow.
Let the coffee machine heat up fully, and then dispense the remaining descaler and water by turning the steam valve counterclockwise to empty the water container. Press "Off" to turn the machine off.
If this does not work then you might require a technician.
THANK YOU FOR VISITING FIXYA
Feb 10, 2011 | Coffee Makers & Espresso Machines
My phone locked and i don't remember my password i need hlep
This should work to perform a Manual Factory Data Reset.
1. Press and hold the Camera key down, then tap the On button.
2. Release the Camera key when advised.
3. A black screen appears, with green writing. At this stage press the Down volume key to select Recovery Mode.
4. An icon appears, showing a triangle containing an exclamation mark above a handset.
5. Slide open the keypad then press and hold the ALT key and tap the W key.
6. The handset will restart to complete the reset.
hope this helps
John
Jan 09, 2011 | Motorola Mobility CLIQ Cell Phone
Nespresso clitz's light is keep blinking. I pressed both button but not working, I turned it on and off and make sure wate container is placed correctly.
It sounds like you've put it into descaling mode. Hold down the "large" button for a second or two and water should start coming through. Press the large button again to stop it. Lift the capsule eject handle and put it back down. Then hold down both buttons for about 3 seconds to exit descaling mode.
Dec 10, 2010 | Nespresso Citiz D110
The water container releases too much water and it spills out the back and sides of the machine
Water container have a small valve which work with a small spring and o ring. You can remove the container over a sink unit fill with water and try to press with your finger to check if it block the water without pressing it and also check visual if their any dirt or scale blocking it from closing full or if the o ring is damages in any point.
In any case the valve work very simple the the spring force down the piston and o ring should block the water from ascape if any of thsi is dirty or damage or the loose then the water will leak.
You should also check the valve base on the machine body since their can be something that blocking the valve sit corectly on base so water can leak out of the piping arount the machine.
Good luck
Aug 15, 2010 | Saeco Trevi Automatica Cappuccino
How do i unlock my phone that my friend locked and forgot the password??
This should work.
Mar 28, 2010 | Motorola Mobility CLIQ Cell Phone
Side by side won't dispense ice.
Take the ice container that has the auger inside it and press the door switch in while you press the dispenser. If the auger motor in the back works empty the ice container and see if there may be frozen ice preventing it from turning. If yes then defrost and dry the container and replace. If this does not solve the problem get me your model number for example 213.256489 for Sears and I will help you track the problem down. Sea Breeze
Jul 23, 2009 | Refrigerators
Only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Jul 14, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker doesn't work after removing all the ice.
what do you mean by "giggled the ice container in the door?"
If I get it well, remove the ice container and look for any switch in its holder( where the container touches the refrigerator body). If you find one check if it's not broken, then try pressing/pushing it. If it seems to work normally, put the container back and try to push it towards that switch to make sure it presses it.
I hope I helped
Apr 16, 2009 | Refrigerators
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
