Question about Garden
Why does my tiller 31cc bolens idle in both a-and b position but dies when i throttle up
mcgyver468
  • 710 Answers
SOURCE: fuel/accelerator problems. dies when accelating or at idle. runs when accelerator held in one position for a short while.
CHECK THE IDLE SPEED SENSOR, UNPLUG IT AND SEE IF THE VEHICLE REVS UP A BIT. IF IT DOES, THEN REPLACE IT. ALSO CHECK THE FUEL PUMP RELAY IN THE FUSEBOX. HOPE THIS HELPS. .LET ME KNOW. GOOD LUCK
Posted on May 03, 2009
SOURCE: Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
Posted on May 18, 2009
panilling9
  • 284 Answers
SOURCE: weedeater carburator setting on bolens 31cc
initial setting is 1and1/4 turns out for walbro carb.
1 turn out zama carb.
Posted on May 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
hunter19_46m
  • 7482 Answers
SOURCE: After Carb Kit install the engine will only run at
You need to readjust your idle/full speed jets...
Sounds like the high speed jet is set too low readjust while running
Posted on Dec 05, 2010
Im the girl asking about my fuel line for my tiller bolens 31cc tiller BL410 I put newlines &new bulb on! Want stay running, changed lines around,cleaned screen but want stay running but few seconds
If it is a 2 cycle motor, check the spark arrest or screen in the muffler. It is a fine screen and the oil in the exhaust leaves a carbon buildup that will plug up the screen. It can be cleaned with a brass wire brush or carb cleaner.
Mar 30, 2017 | Garden
Can not hardly turn engine over with plug in much easier with plug out. Tiller had sat for a few years and I put some oil in cylinder and helped some.Bolens 31cc tiller.
Not sure if you can do this with your particular engine, but if you can take the cowling off and use a heavy drill motor and socket, spray wd40 in cylinder and turn the motor over with plug out using a drill, you may loosen the the old oil or rusty cylinder.
Apr 06, 2016 | Garden
Repair and replace power module on bolens culivator 31cc engine
How old is it? Does it show a spark when you remove plug an hold against engine while pulling cord? Did you replace plug? It is the most common problem. Remove the stop wire an try to start, if it does or you see spark the switch is bad. I would check put these things before replacing module.
Mar 16, 2014 | Bolens 31cc 2-Cycle Gas Cultivator BL410
31cc engine specifications
Engine specifications for the flywheel to magnito clearance: Contact Bolens.
Nov 03, 2017 | Bolens 31cc 2-Cycle Gas Cultivator BL410
Troy bilt trimmer idle problem position 2 shut off
try fresh fuel fuel is only good for 30 days in small engines if not the carb needs a good cleaning
Jul 25, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
