Question about Toro Garden
Toro 74234 Z-Master mower won't shut off when key is turned off??? Runs, but doesn't diesel and slowly quits-
lilmikew99
  • 122 Answers
SOURCE: Toro mower won't start. No sound when I turn key.
definately connection some where i would use a volt meter and make sure where power is and make sure it is getting too where you need it, if its getting too the soliniod or not then too the starter.
Posted on May 10, 2009
  • 69 Answers
SOURCE: My Toro lawn mower starts good, but it only runs
Sounds like you need a carb cleaning. Also install some Seafoam gas additive in your gas tank to clean out the gunk that builds up. Do not use ethanol gas.
Posted on May 18, 2009
carolinabeck
SOURCE: my toro mower disingages the blades after it runs for awhile
ik ben carolina beckers en ik heb met jaak coppens iets gaan drinken
Posted on Aug 08, 2009
rwvanlue
  • 486 Answers
SOURCE: totr model #20479 GTS 5 motor, when you push prime
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 16, 2009
SOURCE: my toro lawn mower will start with the primer
Had this problem after I inherited the same mower. Take the carb off and remove the "bowl" using the bolt at the bottom. You will see a plastic float and a needle valve. Remove the float by puling the the pin and clean the needle vale and ensure it moves freely. Also clean the "jet" that holds the float washer to the carb assembly. Also clean the bolt that hold the bowl on.
Posted on May 03, 2010
Mower was running shut off now does nothing when i turn key
If electric start check for low battery or loose battery cables. Could be a bad starter.
Jun 21, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
Mower was running then shut off. And now when I turn key it will not do anything.
Check the plug and wiring connected to the seat under the seat. May have crimped or come undone. This is a safety feature on most mowers.
Jun 04, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
Toro z master won't start
bypass the safety switches one at a time to test them
Sep 19, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
Mower was running then shut off. And now when I turn key it just clicks.
sounds like your battery went bad...try a battery charger and see if it works that way ..if so then bad battery or not charging the bat. when running
May 19, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
Our Toro, guaranteed to start, won't start. We can cut awhile, then it will not restart. Plug is fine, getting a spark, and not at all wet, can't seem to find the problem. This doesn't...
I have the same problem. One time this happened and it restarted after a few hours and worked fine for 5 more cuts over a couple of months time. Now again it quit mid cut of my yard and would not restart. When trying to start it would fire for a few seconds and than shut off again. I wated a week to try it again and now it does nto fire at all. This is about a year old mower with only about 10-15 hours of total use.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
Toro Z Master Cooling fan will not turn on.
i would check water temp sender in engine block or thermostat housing.take wire off with key switch in on position touch wire to clean ground tis completes ground curcuit to relay fan should come on if so test sender with test lite or ohm meter. should be open curcuit or no lite when cold and go complete or lite when comes up to temp. clamp test lite to sender and probe to positive. hope this helps
Jul 17, 2010 | Toro 60" Cut Zero Turn Rider Diesel...
Toro z master 252, starts ,runs 8 to 10 min. shuts...
One suggestion wouild be to check the spark right after failure. You can buy in-line spark indicators that give you a visual light if you are getting spark. This way you could see if you are losing spark when the engine warms up. If your spark is good, you would want to check the compression after the engine is warmed up and quits. You should have at least 100# minimum.
May 21, 2010 | Toro 54'' Zero Turn Lawn Mower 25hp...
Garden Logo
76 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
