Question about Pure Audio Players & Recorders
I need a new aerial for my dab pure evoke - 1 S radio
4 Suggested Answers
  • 53 Answers
SOURCE: No sound from Evoke-1 DAB radio.
I've seen a few (Pure & other brands) like this.No communications between the micro and the dab module . could be either thats at fault.. Doubt it would be an economic fix. sorry.
Posted on Nov 07, 2009
SOURCE: my Pure Evoke 2 Dab
Telephone Pure and they will talk you through what to do
Posted on Sep 16, 2010
paul9367
  • 160 Answers
SOURCE: pure evoke-2s dab radio stuck on getting time how do i fix it?
here is the manual; for your item
http://www.thiecom.de/ftp/pure/evoke2/user_guide_-_393kb_pdf.pdf
try performing the system reset and autotune as it may be picking up time only from a time server once it has a good connection to digital transmitters, hence if not good connection will not get time and remain in that state, check that your arial connection is good also
Posted on Mar 21, 2017
Pure evoke-2s dab radio stuck on getting time how do i fix it?
Mar 21, 2017 | Pure Audio Players & Recorders
Why will my radio new 3120 not pick up dab stations at all really tune and all I get is radio 2 have tried for a week to get magic fm thank you
If you have replaced a normal car radio with a DAB then your existing aerial is not suitable due to the required frequency range. You need a DAB aerial for cars. There are many types available, internal or external. Don't bother with converters as this will only give a marginal boost to the fm aerial.
Jun 06, 2016 | Cars & Trucks
How do I correct a faulty volume on a pure evoke 2 DAB radio
Most likely the audio amplifier chip needs replacing.Other wise you could try spraying "CRC 2-26" into the volume control assembly.
Sep 28, 2014 | Radio Communications
Pure dab radio keeps cutting out
My Pure Evoke 1S ran fine for years. Then two years ago it started cutting out every now and again, and, at other times, just failing to switch on, by constantly recycling between off and on. The higher the volume setting, the quicker it cut out.
I persevered with the radio because a) it was expensive at £90, b) the sound is very good quality, and c) I could not see a reason for the fault other than a component failure (and there was no obvious sign for that).
I then discovered the fix and it is quite simple. With the radio on, select the menu option "Energy Saving Settings" and set the option to "NO". The radio will works as normal, immediately.
Hope this works for you, too.
May 28, 2012 | Audio Players & Recorders
MY PURE 3 dab RADIO stopped working overnight - it was working perfectly saturday night but was completly dead sunday morning. It has a battery pack attached and i have also tried using another PURE mains...
I have purchased 2 Pure Radios (Mio &Evoke Flow) and have had the eact same problem you mention. It is definately a bug with the radio.
I have had the Mio replaced twice and the Evoke Flow once. 6 months later I had the same problem and took it back and got a credit. I would not trust this brand any longer...
Nov 03, 2010 | Audio Players & Recorders
My Pure Evoke 2 Dab radio has stopped working, it has power but can't get sound stations or anything ...what do i do?
I've got the same problem, from working perfectly to suddenly nothing. "No stations available". Please let me know if you get an answer.
Sep 02, 2010 | Audio Players & Recorders
Pure Evoke 3 circuit
yep, just download a manual (free) from Pure.com.
Feb 18, 2010 | Audio Players & Recorders
I recently moved my Legato Pure radio, now I have trouble tuning in the DAB radio and the display struggles to set the clock often flashing with a message saying it is wating for time to set. When it does...
Clearly, the DAB signal strength is poorer in the new radio position. Try moving it, even a foot or two can make a difference. Better still, use a roof aerial.
The display can be changed, even in standby mode - press the Display button to see the 3 options.
Dec 19, 2009 | Audio Players & Recorders
Nov 07, 2009 | Audio Players & Recorders
29 people viewed this question
Top Pure Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Pure Audio Player and Recorder Expert? Answer questions, earn points and help others
