Question about Craftsman Garden
How to replace mower height adjustment torsion spring on craftsman zero turn mower model 247.250610
    Habit-Forming:
    New Friend:
  • 183 Answers
You can get your owners manual here. It should help
http://www.searspartsdirect.com/model-number/247250610/0247/1506000.html?searchType=modelSearch&q=247.250610&searchTerm=247.250610
Posted on Jun 22, 2017
rockitman187
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
SOURCE: Kitchenaid Microwave torsion spring replacement
I just replaced torsion spring 4452396 on my microwave. We heard a "pop" and then the door got heavy. here are a couple things I learned...THE HARD WAY!
We had the stainless steel front to the door and needed spring 4452396, not 4451008. The stainless steel door is heavier so therefore a stiffer spring. I'm not sure i could justify the 4x cost in the part...but that's just the way it is. It's a bit of a pain to repair the thing..so it's worth it to get the correct spring. You don't wan to be doing this every couple of of months!
You have to remove the front panel of the door to access the springs. there are 2 of them...they cross each other in an "x" pattern on the lower part of the door. We had to pull the unit out a bit to get the spring in the hole for correct position. No need to remove the door etc. If you need help with this...email me.
My mistake was when I was trying to figure out how to gain access to the springs I assumed you did from the inside of the door. I removed the two black things you see on the lower right/left of the door (screw on the bottom of them) then proceeded to remove the two recessed screws on the inside top corners of the door. Well next thing i know.....CRASH! the whole front of the door fell off and shattered! Come to find out those screws and brackets on the bottom hold the face of the door on. The glass is intergrated into the color panel of the door..so it's one piece! 150.00 later and a new piece of glass/panel i learned a hard lesson.
Let me know if you need help...it's fairly easy to do now that I look back on it. dave dlacki@gmail.com
Posted on Jan 09, 2010
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
Posted on Jun 01, 2010
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Posted on Nov 24, 2010
SOURCE: Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
the drive cable broke so i ordered a new one. looking for a answer on how does it connect to underside of mower and the top of mower deck ?
22'' 650 model no.917.376741. thank you.
Posted on Nov 13, 2012
What do I do to fix a loose mower belt on a craftsman zero-turn mower
Your belt has stretched. If there is an adjuster available, via pulley, use it till there is no more adjustment. Otherwise, remove the belt and replace with a new, proper size belt.
Sep 08, 2015 | Craftsman Garden
How do I adjust the height of the front wheels?
U need a shopmanual. U may not have propr tools. Cud b a safety issue tu. A mechanic w experienc probly the way. Dont go to a dealer
Jun 04, 2015 | Briggs & Stratton Craftsman 42" 22hp...
How to replace a torsion spring to a mowing deck and defector ?
Go to the Sears dot com parts site and enter you model number. They will have diagrams that will help you. Model and year would be helpful. Hope this helps please post comment if it does.
May 08, 2014 | Sears Craftsman 46 in Mulching Tractor...
The deck wont stay in a position i set.
its the torsion spring im replacing mine because it broke. if you are going to fix it yourself dont do it you have to take everything apart and its a pain!!!!! just use a zip tie to hold it in height adjustment that you want i wish i would have!!!!!!
Apr 19, 2011 | Mustang Rzt 50" Zero Turn Riding Lawn...
Torsion spring is broken for our liftmaster 2265R model garage door opener and i need a new one where do you buy one?
Here are instructions for replacing the spring. You can call any local garage door company and they will sell you the springs. I absolutely don't recommend this job for a DIY'er. It is dangerous.
http://ddmgaragedoors.com/diy-instructions/replace-garage-door-torsion-springs.php
Feb 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Door openly opens 5-6 in, then stops.
If the door isn't unusually heavy when you open it manually then maybe an adjustment will help. On the back of the motor unit you will find the 'up force' control. Increase it 1/4 turn and try.
Jun 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
