Question about Kitchen Ranges
ON returning serve, if pickleball lands in the kitchen is it considerd a fault?
I can not get it to crank i changed the coils but still no spark whats next
Best to get a Toyota mechanic . read out fault codes and go from there . you could keep changing parts and get no ware . if you don't know were the fault is . and most times if the parts have been fitted you can't return them.
Mar 31, 2015 | 2001 Toyota Land Cruiser
What is a pinch serve?
The ball will land between the floor and the side wall. It gives the ball a weird spin and reduces the speed of the ball. This makes it really hard to return the serve. You want the ball to land really close to the floor and just fall down there.
Jan 17, 2013 | Sport & Outdoor - Others
I just moved to Nebraska and I can't seem to find any pickle ball players in the area. Do you have any idea where I can look?
Thanks to social networking it is possible to find just about any group of people these days. I was able to find for you a group called "Pickle ball nation" on Facebook. They have over 6000 active members and maybe some of them are in your area. If they are not, I'm sure someone in the group can hook you up with someone who is or a place to go and look for a match. Check out their Facebook group on the link below:
https://www.facebook.com/pickleball
Jan 14, 2013 | Sport & Outdoor - Others
Over range microwave model jvm1650wb008 fan works nothing else does
Check to see if circuit breaker is tripped in the electrical panel, or if it is connected to a ground fault outlet, it may have tripped. Sometimes there is one ground fault outlet serving others in series in the kitchen.
Nov 25, 2011 | GE Microwave Ovens
The stove gives an error code F11
this is a shorted key pad code.you can unplug the range for a few minutes.then plug it back in if the fault returns you need to replace the EOC.
Feb 08, 2010 | Frigidaire FEF336BC Electric Kitchen Range
No oven no burner
The F13 indicates a problem with the EOC (Electronic Oven Control board). This can be caused by a power surge or glitch through the electrical supply lines. You can try disconnecting electrical power completely from the range by unplugging it. Leave it unplugged for a few minutes. If the fault code returns when you plug the range back in, then the EOC will need to be replaced.
Dec 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Squeaking from clutch
hi my name is neil and im time served on land rovers this was a problem with the first ones that came out and it was the clutch that was at fault. it was made on the cheap and needed to get replaced most landy dealers should be able to do the job in under 3 hours but i think the book time was 6 so if you do get it done watch them do it so they dont over charge you.
Dec 16, 2008 | 1997 Land Rover Defender 90
The fuel pump on my 84 range rover will not switch off after the pressure has built up, and keeps on flooding the carbies. Could you give me some solutions to the problem thank you.
have you made sure fuel return line is clear(if fitted)Disconnect fuel return line,remove fuel cap and gently blow compressed air down the line.Another person can listen at the fuel filler for the sound of bubbles and air to confirm its clear.If memory serves you have the solex style carb you may have to check that they are in a servicable condition(needle/seat etc).Have you fitted an after market hi volume fuel pump?
Nov 02, 2008 | Land Rover Range Rover Cars & Trucks
1997 Plymouth Breeze
Most probably ur crank position sensor or the pick-up coil is defective (or nearly). What that does is the computer knows where the No.1 cylinder is so that he knows when to send the spark to the correct spark plug. Now ur computer doesn't seem to know where the No.1 cylinder is, so he fires at random. Eventually the spark lands at the right place at the right time, hence ur engine is long to start.
That is my best guess.
Sep 04, 2008 | 1997 Plymouth Breeze
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
