Question about LG Televison & Video
I need to disable hotel mode on my lg tv. - LG Televison & Video
    Sergeant:
  • 111 Answers
Posted on May 02, 2017
SOURCE: DMTECH TV IN HOTEL MODE
Did you get any solution on this problem? I have the same.... Just out of warranty :(
Please contact me on:
jonas AT teknikbolaget DOT com
Best regards,
Jonas Persson
Sweden
Posted on Jul 11, 2009
  • 325 Answers
SOURCE: Lg hotel tv. t.v. button are locked out, only hotel remote works
Hold down the MENU button on the remote for approx 5 seconds. Then enter 1105 this will access the hidden hotel option on the LG tv so you can change whatever you like..
Cheers LITTLE DISH FITTER
Posted on Sep 01, 2009
  • 325 Answers
SOURCE: stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
Posted on Sep 17, 2009
SOURCE: Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Posted on Sep 28, 2009
  • 3 Answers
SOURCE: 32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Posted on Feb 06, 2011
Hi i have a LG BEJ32LP1DA tv in hotel mode, do Anyone know how to disable it? Thanks
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in " Hotel mode" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 11, 2015 | LG Televison & Video
How do i get my lg32lx4dc tv out of hotel mode?
You have to enter its service mode option to release the Hotel mode. For that, you should have its 'Service Remote Control'; not the user remote control. It will be best to contact the authorized service center for LG. google.com/+GopakumarGopalan
Jun 08, 2015 | Televison & Video
Helllo, wanted to know how to get out of hotel mode
The following are for LG TVs: From your remote, push MENU button for 5 seconds then type 1105 and press OK. You should now have a special menu displayed where you can modify the settings or disable hotel mode. Use the same procedure to go back and modify or enable hotel mode.
Oct 20, 2014 | Televison & Video
Service menu lg 37lh260h
your best and maybe only hope is to call the hotel unit for LG (not part of the main unit) to see if they will help or refuse you.
Nov 05, 2012 | LG 37lh260h 37" 1080p 1920 X 1080 20000:1...
Can not program to my tv or sat or pinneer eqp.
your tv is in hotel mode. setting menu is disabled, try these universal steps
1st power off tv
2nd power on and press a key, while power on and release key. When is the right combination, appears setting menu and change from hotel mode to normal mode.
Jan 16, 2010 | Sony KDF-E55A20 55 in. LCD Television
I bought a 32LC5DC Lg tv from an hotel auction. The side panel doesnt work. The thing I need to find is how to access the "setup menu" inside the regular menu. I can get into the regular menu just fine,...
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
Oct 01, 2009 | LG 32LC5DC 32 in. LCD HDTV
Jul 28, 2009 | Akai Televison & Video
Jun 08, 2009 | Televison & Video
LG 32LX3DC 32 in .Model
Hello Dupree71
The first thing I would do as its from a HOTEL is take the LG telly out of HOTEL MODE. follow the steps below, This should allow you to change the settings on the telly and store them. So when you turn the tv back on it will not revert back to the hotel Options
TV turned on. Hold down the MENU button on the remote for approx 5 seconds then type in 1105 this will take you to the LG hidden Menu.
in this menu there will be hotel mode turn this option off.
This will allow you to save your own setting without it jumping back.
When you follow my steps and its sorted for you please leave a thumbs up for me Please
Thanks
Little Dish Fitter
May 29, 2009 | LG 32LX3DC 32 in. LCD HDTV
Jan 17, 2009 | Philips RC2573 Remote Control
Televison & Video Logo
230 people viewed this question
Computer Repairing
Computer Repairing
