Question about Kitchen Ranges
On returning serve, if pickleball lands inside kitchen is it considered a fault
My visual land tablet will not turn on even when i charge it what could be the problem ??
The tablet is bad, the charger is defective or the tablet is just frozen. Try pressing and holding the power button for 20 seconds, or look for a pin hole on that back and stick a paper clip it in for 20 seconds. If neither work consider replacing the charger and if that doesn't help return or replace the tablet.
Oct 10, 2014 | Visual Land Connect 9" Android Tablet...
What is a pinch serve?
The ball will land between the floor and the side wall. It gives the ball a weird spin and reduces the speed of the ball. This makes it really hard to return the serve. You want the ball to land really close to the floor and just fall down there.
Jan 17, 2013 | Sport & Outdoor - Others
Where did pickle ball get its name considering there are no pickles involved?
Legend has it that when Joel Pritchard, William Bell and Barney McCallum made up the rules for pickle ball in the mid-1960s, Joel Pritchard's dog kept getting in the way. Pickle, as the dog was called, would chase after the discarded balls and disrupt the game. Thus, the game became known as pickle ball.
Jan 14, 2013 | Sport & Outdoor - Others
Over range microwave model jvm1650wb008 fan works nothing else does
Check to see if circuit breaker is tripped in the electrical panel, or if it is connected to a ground fault outlet, it may have tripped. Sometimes there is one ground fault outlet serving others in series in the kitchen.
Nov 25, 2011 | GE Microwave Ovens
Squeaking from clutch
hi my name is neil and im time served on land rovers this was a problem with the first ones that came out and it was the clutch that was at fault. it was made on the cheap and needed to get replaced most landy dealers should be able to do the job in under 3 hours but i think the book time was 6 so if you do get it done watch them do it so they dont over charge you.
Dec 16, 2008 | 1997 Land Rover Defender 90
The fuel pump on my 84 range rover will not switch off after the pressure has built up, and keeps on flooding the carbies. Could you give me some solutions to the problem thank you.
have you made sure fuel return line is clear(if fitted)Disconnect fuel return line,remove fuel cap and gently blow compressed air down the line.Another person can listen at the fuel filler for the sound of bubbles and air to confirm its clear.If memory serves you have the solex style carb you may have to check that they are in a servicable condition(needle/seat etc).Have you fitted an after market hi volume fuel pump?
Nov 02, 2008 | Land Rover Range Rover Cars & Trucks
My land rover is saying
Being a Land Rover tech for about 2 years now, a suspension fault light could mean a hundred different things. ONE of the most common is the compressor failure. But alot of time when the compressor fails it is due to a leak in the system. So make sure you check for leaks before you throw a 300 dollar compressor only to have it fail a month later.
Jul 26, 2008 | 2005 Land Rover LR3
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
