Question about Building Materials
I need a new transmitter for model 88900. I cannot get it to reset.
Model c87214. Why does it keep losing outdoor temp signal?
I have had that experience. You may have to repeat initial installation once more before concluding the system is n.g. Remove batteries from the indoor receiver. Review the instructions and verify transmitter was installed in correct location. Do this as you are removing transmitter batteries. For luck, install new batteries in the transmitter. At the receiver, reinstall batteries (or install new batteries). After approx. 10 min., you should see temperature displayed. My LaCrosse system has its wacky days, sometimes displaying no temperature or an abnormally high temperature when morning sun hits the transmitter. Also, successfully resetting is a once-in-a-blue-moon affair.
Dec 28, 2015 | Measuring Tools & Sensors
Can not get the RF transmitter to work after replacing battery, is there a reset process?
If the transmitter needs resetting Google the model number of the unit for a a 'manual" which will have instructions for this.
Jun 14, 2012 | Cars & Trucks
Skyscan model 88900 atomic clock
This model is discontinued but did find a manual. Click on this site to access the manual. Also, you may want to print it for future reference.
Nov 13, 2011 | Audio Players & Recorders
Model 88900 skyscan atomic clock
Go to link for the manual....
Nov 13, 2011 | SkyScan 86709 Atomic Wall Clock
What does TX in a battery symbol mean?
For Models 88900/901 TX in a battery symbol is the Low battery indicator (Sensor)
RX in a battery symbol is Low battery indicator (atomic clock)
Source: Page 4 of the manual.
Jun 16, 2010 | SkyScan 86709 Atomic Wall Clock
88900 Atomic Clock does not read time and temperature.
Batteries must come out of both the temperature sensor (transmitter) and base (clock and temperature display). Leave out for about 4 minutes. Replace the batteries in the temperature sensor FIRST and set it about 5 - 10 feet away from the base. Replace the batteries in the base and leave them both set without touching any buttons for at least 15 minutes (usually only takes 5 minutes or so). The temperature should start to display. You can set the clock manually to the correct time and have it get the updates via radio in the evening or night. Should work after all this just fine. (have done it alot of times this way over the years)
Good luck.
Mar 20, 2009 | SkyScan 86709 Atomic Wall Clock
I have a skyscan atomic clock, model 88900. I've absoltely LOVED it until the outside temperature quit being displayed. I have changed the batteries 2x's according to the instructions and have used NEW...
This is a very common problem that is most frequently caused by the outdoor transmitter going bad. They are surprisingly delicate and don't like getting wet.
You can order replacement transmitters from
They only cost $11 and that includes shipping and handling.
Jan 25, 2009 | Audio Players & Recorders
Skyscan Atomic Clock WWVB
figure out where yu are north south west east zones on your map from where yu are , then pull battery again it should stop at for eight or twelve push time zone then set in a window facing your zone it should automatically pick it up shortly in awhile
sw i think it may stop at four also but then wait
Oct 14, 2008 | SkyScan 86709 Atomic Wall Clock
Temperature Transmitter
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
Building Materials Logo
32 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
