Question about Samsung Televison & Video
Samsung 2016 Curved TV with a caption that reads "ICING NEW DEMAND" stays on all the time, is about eye level. How do I remove it.
4 Suggested Answers
  • 205 Answers
SOURCE: turn on closed caption on samsung LA32S81B tv
If you don't have the manual, go to this website:
http://www.samsung.com/in/support/productsupport/download/FileView.aspx?cttfileid=1383390&type=TV&typecode=&subtype=LCD+TV&subtypecode=&cmssubtypecode=&model=LA32S81B&filetype=UM&language=&LSSI=/in/module/ssi/left/lmenu_tv_sonomatrenz.sec&RSSI=/in/module/ssi/right/rmenu_tv.sec
and download it. I think Samsung refers to it as Teletext. Instrucitons are on page 31 of this manual.
Good luck.
Posted on Dec 09, 2007
  • 333 Answers
SOURCE: close caption writin words display all the time on tv how do i
Go to menu aand look for tv settings. go to closed caption and continue to scroll untill you see off
Posted on Nov 26, 2008
mjap
  • 107 Answers
SOURCE: Power on T.V. keeps cutting on & off every second.
I believe that your TV's had a bad soldering. resoldering all the circuits may help.
if you bang or tap the top or side of your TV the video, sound, or anything will move or something happen.
warning: TV's has a high voltage. I prefer you to be careful if you open it.
have a good day and take care.
Posted on Jan 16, 2009
Where's the fuse on flat-screen western tv
There are few technology tragedies as sad as a dead big-screen TV. Sharp-eyed readers may recall that I suffered just such a misfortune in November 2010, when my nearly 5-year-old 42-inch set dropped dead unexpectedly. At the time, I described the scene as follows:
After attempting to revive the set by turning it off and on, unplugging and reconnecting the power plug, and other basic troubleshooting, I had to face the hard conclusion that my television was dead.From there, I detailed the research, purchase, and installation process for my new plasma, a 50-inch Samsung 3DTV. That new set has been great, even if the 3D highlight so far has been the 3D Yule Log special on one of Time Warner's on-demand channels. For a complete accounting of how I chose my new TV, you can read the full blow by blow here. I'm sure I could have done some additional troubleshooting on the dead TV at the time, but a good reason to upgrade to a new flat-screen doesn't come along every day, and I was probably looking for an excuse.
Mar 16, 2017 | Televison & Video
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
Frozen display
hi on the remote control press the i button this should remove the caption, go into the menu on the tv select display setting check the time out hope it helps
regards
shaun
Apr 02, 2014 | Samsung Televison & Video
Samsung remote for HT-D5550 not working with BD - only TV - HT-D5550
Wipe the front, where the receiver eye shoot be with a soft clothed cloth.
Otherwise there is no new equipment connected like a kodi player or so? It demand sometime a slot and block other equipment.
Feb 04, 2018 | Samsung Ht-d5500 Blu-ray Receiver
How do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Jan 16, 2009 | Samsung DLP HL-P5663W 56" TV
Closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Nov 14, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Apr 14, 2007 | Samsung LN-R3228W 32 in. HD-Ready LCD...
Closed Captioned
Assuming whatever your TV receiving from has close caption. (Not all TV channel has close caption) Solution 1) Get a new universal remote that support your model and has close caption button. Once you program in the code for your TV model and it works then all button should also programmed including th close caption button. Solution 2) Search online for the owner manual and read see how to turn it on using buttons on TV (if possible). Solution 3) Get new TV with close caption. (If you have an old old TV with bad and huge pixels then this solution is the best. Your eyes will thank you.)
Aug 25, 2006 | Panasonic CT-32G11 32" TV
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
24 people viewed this question
Jerry Greenberg
Jerry Greenberg
