My machine is failing to wash - Washing Machines
Top loading Gorenje WT 52113, it stops a few minutes into the washing cycle, an error message comes up on the small digital display, looks like d02?
This washer only has f fail code, they recommend you contact svc person for repair. Fail code for F02: F2 Door lock fault detected The door lock on the washing machine has been detected as faulty or failed to engage correctly.
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Aug 12, 2016 | Washing Machines
Failing to Load Water
How old is it ???
Jun 16, 2013 | Washing Machines
Estate washing machine agitaror stopped working
Possible that the motor is jammed, the motor has failed or the motor capacitor has failed or is weak. You must first use a multimeter to check the voltage on the motor during the wash cycle. If there is no voltage the fault is failure of the controller unit if water is flowing in and the level sensor also works.Check this link for tips: http://www.espares.co.uk/advice/washing-machines/a/7/1270/how-to-fit-a-washing-machine-drum-paddle.html
Mar 14, 2012 | Maytag Washing Machines
Washing machine makes a loud vibrating noise when spinning and sprays grease onto washing
It sounds like the main bearings have failed, try turning the drum by hand, if it feels rough or is niosy, then the bearings have failed.
Oct 25, 2010 | Hotpoint Washing Machines
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washing machine not filling up with water.
There are 3 possibilities.
1. The water inlet valve solonoid (hot or cold) has failed.
2. Pressure switch (tells water level of machine) failed.
3. Timer Failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 22, 2009 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
