Question about Ariens Garden
Ariens rt7020 Tecumseh 7hp need engine number so can get carb for it
    Sergeant:
  • 111 Answers
Parts not available for Ariens ST724 7hp snow blower?
As far as the bolts you should be able to match them at a small engine and lawnmower repair shop and as well if you take the old recoil they might be able to get you what you need.
Nov 10, 2014 | Garden
Parts not available for Ariens ST724 snowblower?
No you do not..you have the model number and hp should do it ..go in on your computer and just put the name,model number,hp and model in that order .or better yet go in on eBay and put that in and most likely you will find it a a reduced cost..good luck
Nov 10, 2014 | Ariens Snowblower Belt 72098, 8hp 1/2 X 37...
I have an Ariens ST724 7hp snowblower (model:924075 serial 005629) that needs to have the starter cup, recoil, and the 4 bolts that secure the recoil replaced. The problem is all of these parts are NO
In order to order engine you must look-up the engine itself. If this blower still has the original engine then it is a
Tecumseh HSK50-65496
Recoil Part Number TEC590604 Image
t_590604_000.jpg This item has been discontinued by Tecumseh, part number STE150-003 will work but does not have the handle cup.
Original Tecumseh Part
Replaces Tecumseh 590604 and 590605
Fits Models: H, HS, HSK
For use on Snow King Models
RECOIL STARTER ASSEMBLY TECUMSEH 590420A
I just bought a Ariens old snow blower Mod#ST504. It is 5hp. Mod# 932006, Ser# 023321. I need a new carburetor the only # I found on the 7389j7 it does not match any # on line?
You need to look at the Oregon brand of replacement parts as Tecumseh shuttered operations in 2009... Oh and those aren't Tecumseh numbers
Oct 18, 2014 | Garden
My 7hp tecumseh engine on an ariens tiller will run great until the engine gets really warm. Then it will die. I will restart it immediately and it will run for about 30 seconds and die again. Ive...
A few possibilities to check:
1. The chock is stuck on. Pull the air cleaner while running and see if the chock is closing off part of the throttle.
2. Check the OHV valve settings, could be the tolerance is too tight.
May 27, 2011 | Garden
I bought an ariens 932027 ST724 W/ 7HP Tecumseh HSK70 130266S Engine. It seems to have a problem running for longer period of time than 5 or 10 min. after that it starts back firing and shuts down. It will...
Almost certain, having had this problem with this mower several times, that your petrol cap which is suposed to let air into the tank does not. after a few mins of running suction develops and the engine stops. you check the fuel level and its ok so you restart and it goes fine for another 5 min. by removing the petrol cap you let air in and temporarily fixed it. Clean out the arangement of screws and springs and filters under the fuel cap.
Dec 28, 2010 | Sport & Outdoor - Others
I have a 1984 ariens snowblower with a Tecumseh and no spark
Electronic Ignition was introduced on many engines about that time frame. I would need to have model and type numbers from the engine to fully determine that question. However, have spark is still the issue. If the unit has a switch installed on the operator's console, it should be disconnected at the engine so that any safety switches are not masking or causing a problem that is not engine related.
Let's investigate a few basics first.
a) How have you determined that there is no spark?
b) Have you used a type of spark tester?
c) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Nov 13, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens ST724 carb issue
You'll need the model and serial number and also the carb will be helpful, if you take that info and the carb to your local lawnmower shop they will be able to supply you with the right kit.
Dec 31, 2008 | Garden
Garden Logo
24 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
