Question about Dimplex Heating & Cooling
Question was about Dimplex electric fireplace
  • 3284 Answers
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Posted on Dec 13, 2008
  • 92 Answers
SOURCE: 15 Amp circuit breaker keeps on tripping , as as
breaker tripping right of way means bad breaker or dead short. which means something has burned out or is wired incorrectly
Posted on May 14, 2009
  • 232 Answers
SOURCE: I need a wiring diagram
you can get from www.dimplex.com
Posted on Sep 15, 2009
  • 288 Answers
SOURCE: Heater works but fan does not
if you have a tester, take off the panel to expose the fan. (turn off power) disconnect the wire leads and connect each of your test leads to the wire. Your meter will need to read ohms. if you have any resistance, then the fan should work. If you get a reading of zero or OL then the fan needs replaced. If the fan is good, then there is a switch that should close on a rise in temperature that may be bad. I am speculating that the sensor is close to your electric heating element.
Posted on Dec 06, 2009
  • 4736 Answers
SOURCE: the fireplace blower does not
This is a constant problem for ALL electric fireplaces with heaters. Either the Owners Manual fails to the manufacturer not telling you that the heating elements need routine cleaning, because they are sucking in household air to heat it and send it back out, So whatever is float in your household air (dust, lint & pet hair) near the floor goes into it, clogs it up and causes the heating element to overheat and fail. Or customers who have purchased these units don't read the Owners Manual.
These units, no matter who the manufacturer is were not designed to heat for long periods of time. In fact the heater element doesn't produce much more heat that a blow drier on high heat.
The heater and the blower and are in the lower compartment of the firebox. If you can access it, you can clean it with a shop vac and a brush attachment on the end of the hose. Be sure to unplug the fireplace from the wall outlet before attempting this. If cleaning it doesn't help, the blower motor will have to be replaced. You can order one from Dimplex USA.
Posted on Feb 06, 2011
Dimplex optiflame remote not working
The DFI2310 uses a simple plug-in remote.
You can either order one from Dimplex, or use an aftermarket solution such as this one from Skytech: Skytech 1315G Electric Fireplace Remote.
Oct 08, 2012 | Dimplex DFI2310 23 Inch Deluxe Electric...
What type of bulb is required for the mcn20 dimplex fire thank you
Steve, a 60 watt, small base, chandelier bulb is what is required. There are usually 3 to 4 of them in most electric fireplaces.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Our dimplex electric fireplace model number 28106D3F shut off and won't turn back on
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall receptacle and leave unplugged for 10 - 15 minutes. This will give it time t reset itself. In the future, if you finding you're have to do this more often. Unplug the fireplace, stop using it and call Dimplex USA Technical Service 888-346-7539 for further instructions.
Mar 09, 2011 | Heating & Cooling
Will someone fix my fireplace,it sparked and zapped then I shut it down
If it's still under the 1 year Manufacturer's Warranty, Dimplex will repair or replace at their option. If not within the warranty period, unfortunately, you're on your own.
You can contact Dimplex USA Technical Support at 888-346-7539, Monday - Friday,8:00 a.m. - 4:30 p.m. EST. They can help you trouble shoot the problem.
Mar 03, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Jan 31, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Remote control working with fireplace.
Dec 13, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
20 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
