Question about Water Water Heaters
Hot water tap leaking what can i do - Water Water Heaters
  • 111 Answers
That is a simple fix - you need to replace the cartridge that is in the faucet handle. however, each manufacturer is different. NOTE sometimes you need a specially designed removal and puller tool. I found this out the hard way. I had a Moen faucet and needed a collar removing tool and a cartridge puller in order to remove the cartridge.
hot water tap leaking what can i do - shopping-agkhgscnsed5ttrxyrg0l1ae-3-0.jpg
Posted on May 01, 2017
Boiler working ok ? but the waters not getting hot
Check if you have a leak running all the hot water out of unit...
Do this by turning off all taps, and put ear against pipe... listen for running water.
.. another test: wait one hour without any water usage and check before and after water meter reading.
Jan 27, 2017 | Water Heaters
Hi my vulcan gas hot water service isn't getting hot enough anymore? please help me?
check first if you have good water flow to and from heater. lift pressure release valve on inlet and allow few sec to flow, same with outlet hot water safety valve.
remove front cover from the heater, you should see your gas connection and thermostat knob.
check if gas is burning evenly and on whole surface, check for leaks on the heater and on the lines to and from the heater.
if you did not find any faults, no leaks, safety valves work correctly, check thermostats settings,
wind it down to minimal, then turn it to about 1/4 value (you did not specify model but this should do, widening arrow or numerical values ar self explanatory), lift hot water safety valve for few seconds, then open any hot water tap (faucet if you are an american...) and check if gas ignites and burns.
set thermostat to about 2/3 value and again, lift hot water safety valve for few seconds, then open any hot water tap. check if gas ignites and if water is sufficiently hot, if too hot - wind it down to say 1/2 way, if too cold, wind it till resistant and then back off a bit, DO NOT EVER LEAVE VALVE OR THERMOSTAT ON MAX!.
if none of these help - you need either, change the thermostat or heater itself.
if works - you solved the problem, close the tap, close the cover and use the system as you normally do.
i am always recommending use of insulation on the hot water system, it saves heaps of money over the life of the system.
hope this will help you - do not forget to vote... :-)
Apr 09, 2015 | Water Water Heaters
I have a new Bradford white 40 gallon gas hot water heater. There are no single handle faucets. The hot water fluctuates between hot and cold. When I close both inlet and outlet shut off for the hot water...
Sounds like water leak.
For example, broken pipe... or water running out of TP valve.
That would explain variable hot-and-cold water at tap.
Turn off all taps, and observe if water meter is registering water usage.
Jun 15, 2014 | Water Heaters
Insinkerator hot tap faq
Check all the connections, take the cover off after you shut down the power. If the connectors are not leaking, replace it
May 04, 2013 | In-Sink-Erator InSinkErator HC-WAVESN-SS...
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Gas ignites flame but water is not getting hot
You have gas water heater with working burner.
But not getting hot water at faucet?
1) Bad faucet cartridge. Test for crossover. Copy following link:
2) Is there hot water inside the tank? Open drain valve and check for hot water.
3) Drips and leaks: Turn off all taps and put ear against pipe and listen for water leak.
Water leak can run all the hot out of tank.
Dec 05, 2012 | Water Heaters
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
Jul 02, 2011 | Water Heaters
Hot water not very hot..also seems low in pressure
pressure temp valve leaking
tank leaking
hot water line leaking
shut off water to tank and leave sit for 4 hours turn on water tap and test temp if hot you have a leak
Oct 17, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have hot water coming out of house taps but not from out of the shower, we do not have a bath tub. there seems to be no obvious leaks. HELP! what can i do i have 4 stinky kids that badly need a shower
The tap fitting on the shower may have failed. Some of the modern fittings have a more complicated internal mechanism than the traditional taps and can fail rendering the tap inoperable. Turn off the water at the mains. First take off the tap handle and then with a spanner carefully unwind the tap spindle. Be very carefull not to use excessive force in case you damage the pipework behind. If it does not come ralatively easily leave it for someone else. When you have this out have someone crack the main valve and you should have hot water coming out. If the fitting itself is the problem you may be able to take the spindle and washer out of a standard brass garden tap and use it as a temporary fix untill you get a propper replacement. Just another thought, you may have an isolation valve on the hot water line to the bathroom. Could a kid have turned it off?
Aug 30, 2009 | Rheem Tankless Hot Water Heater...
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
