Model # CFP3811GB. Serial # 15507D6F 132. The heat is not blowing out the front. How can it be fixed?
Where is serial number located?
Hi Kay!
If you are looking for the serial number of the mower, it should be on a sticker on the back bumper near the bottom of the seat.
See this guide for an example:
John Deere Model Number Locator
Hope this helps!
Aug 17, 2015 | John Deere 132 425 Lawn Tractorsnow...
My honda repsol red light comes on and the heat gauge go's 132 what could be the problem
Empty coolant tank. Don't run it until the coolant level is checked and at the correct level. If this doesn't fix it you could have a failed coolant pump.
Oct 06, 2012 | Honda CBR 1000 RR Motorcycles
When I turn on the heat in my 2004 mazda mpv the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
When I turn on the heat in my 2004 mazda mpvicon1.png the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
Jan 14, 2011 | 2004 Mazda MPV
Dryer isn't heating. It turns and blows air but
make sure lint screen and vents are clean. next shut off electric and check heat element for broken element. then get model # and serial # order and change thermocutoffs located on heater box and fanhousing ck these steps one by one
Dec 09, 2009 | Kenmore 75962 Gas Dryer
Whirlpool gas dryer, no heat and no flame
check you thermal fuse with an ohm meter if selected only air and close the door and no air comes from the rear where the vent hooks up clear the vent blower housing then check the thermal fuses on the units exaust assy inside the unit
Aug 19, 2009 | Dryers
I need to find a place to buy parts for my mantis
Try this site.
http://www.alamia.us/SearchResults.asp?Cat=132
Eric
Jun 24, 2009 | Mantis Tiller
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
