Question about Carrier Heating & Cooling
What size filter does carrier model fa4anf048 need?
    Sergeant:
  • 111 Answers
I have a carrier a/c with the model number of fb4cnf036, I need to know what is the proper size for the air filter. thank you
One thing you have to be aware of is some 20×20 filters are 19.5 ×19.5. This is due to the difference between residential and commercial grills. Some 20×20s are in fact 20×20. Measure with a tape measure and make sure your filter size IS THE ACTUAL FILTER DIMENSION!! Good Luck!
Aug 11, 2017 | Carrier Heating & Cooling
I have a Carrier heating unit in my attic ,
zone controller might be stuck seek help from service co.
Mar 25, 2015 | Carrier Heating & Cooling
Carrier model FCBNF030 where is the filter located in the unit?
There may not be one. Most filter messages on a thermostat go by accumilated run time. They are just a reminder and the thermostat message has to be reset. If its there it would be at the unit inlet were the return plenum connects to the unit. They dont usually have both if you have filters in the return grills you dont need them at the unit.
Jan 13, 2014 | Carrier Heating & Cooling
Carrier weathermaker 8000
The filter should slide out of a built in rack from the side of the furnace by the return inlet. It should have the size on it or you'll have to measure it. It may also be inside the bottom door. Pull the door up and out, the filter will be on one side or the other. Unless you have a special Hepa or electronic filtering system.
Dec 12, 2013 | Heating & Cooling
CARRIER FILTER FOR MODEL FA4BNF030
I can't find a filter to fit my Carrier air conditioner it needs 16 1/2x21 5/8x1 where can I find this can you please help, thank you
Jun 25, 2012 | Carrier Heating & Cooling
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
Need Size for my filter, unit Carrier Model FA4CNC036
I assume the filter goes in at the bottom of the air handler. Carrier, in their infinite wisdom, uses the oddest sizes of any units. Use a tape measure and measure the depth and width of the opening.
It may be something like 19-5/8x21. You can't buy these off the shelf at home supply stores.
You will have to find a heating and air supply store to get them.
Hope this helps.
Sep 03, 2011 | Heating & Cooling
Just moved in. Trying to figure how to set thermostat so actual heat comes out. I have tried everything. Only cool air comes out and the House temp stays the same...Cold. Carrier Model No. FA4ANF048.
You have a problem both on the inside unit as well as the outside unit.
The outside unit is not coming on due to a failed contactor relay,bad capacitor or low refrigerant. The inside E-heat is not coming on because of a failed heat sequencer or limit switch.
If you have tools and a volt/ohm meter I could walk you through it.You would be dealing with live high voltage as well as low voltage.
If not.
The problem will require a local HVAC technician.
Dec 22, 2009 | Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
