Question about Stihl Garden
Stihl ms180c won't run at full throttle clean carb professionally 30 minutes later same problem Could it be something other than carburetor problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
May be that the Gas tank vent is clogged. If you shut the saw off, crack the gas fill cap and start it again, will it run strong again?
Posted on May 02, 2017
  • 48 Answers
SOURCE: will only run with full choke and absolutely no throttle.
Carbs gummed up. Need a serious cleaning or a full ruubers replacement/rebuild kit. Gas turns to gummy when left stting in the fuel bowls.
Use a couple of cans of Sea Foam.. best stuff in the world.
Posted on Mar 20, 2009
  • 218 Answers
SOURCE: I have a stihl fs76 weed trimmer. It will start
Hi..my name is Keith...it sounds like the reeds in your carb needs replacing...usually if you use a carberator cleaner on them..it will ruin them..plus age will make them stiff..they should be as soft a rose petal..and its cheap and inexpensive to replace..but you have to pay attention to how many layers and the shape of the reeds that come out..because the kit that you buy will fix several different carbs..i hope this has helped..if not..write back
Posted on Jul 01, 2009
  • 85 Answers
SOURCE: Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Posted on Aug 19, 2009
  • 389 Answers
SOURCE: Stihl MS290 only runs if the gas tank vent valve
sounds like you have a plugged vent either in the gas cap or the vent valve of which you speak. Without the vent working properly, the engine running and drawing gas from the fuel tank causes a vaccum inside the tank making it harder for the fuel to draw to the carburator. this would cause the symptoms that you are talking about.
Replace the gas cap if it is vented or check to see if the vent valve you mention is working properly.
Good Luck
Posted on Dec 21, 2009
2strokeJim
  • 577 Answers
SOURCE: stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
check your muffler screen for being plugged, this will cause it to not accelerate
2StrokeJim
Posted on Nov 19, 2011
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Why are the carburetors leaking gasoline?
clean the carburettor.maybe there is a clot on float chamber
Jun 10, 2014 | 1982 BMW R 100 RT
Stihl trimmer must use choke for full throttle
Sounds like a tuning issue and carb problem. Before you go spending money on carbs or carb kits and start stripping down the carb, try this first.
*Unscew both H and L tuning screws ( not all the way out but back them off)
*Pull over until the engine fires up, it should run for a second and cut out.
*Screw both the H & L all the way back in.
*Then reset the carb to standard settings.
*Unscrew the H tuning screw 3/4 of a full turn.
*Unscrew the L tuning screw 1 full turn.
This should be the standard settings.
Start saw as normal and see if its any better. Failing that your probably looking at cleaning the carb or replacing diaphrams.
Apr 19, 2013 | Stihl Trimmer Zama Carburetor...
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
Stihl ms180c handle bar removal
How do you replace the handle and throttle trigger assembly on a ms180c
Feb 11, 2013 | Stihl Garden
Stihl ht70 will only run with the choke full on. New carb no help.
also make sure to clean out the spark arrester. it can cause back pressure and damage gaskets. also stops power..
Nov 17, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
Stihl FS200 repair manual
I just saw this deal on the Fs200 Stihl Brushcutter. Equipped with a Zama c1qs51 carb. Junk the carb. Go to a stihl dealer and buy a three screw chainsaw type carb with a high low and idle screw. The c1qs51 is junk.The three school carb will put an end to your worries. Of course change your fuel filter naturally. I guarantee this will fix the thing. I own an Fs200 and Fs250.
Jul 15, 2012 | Garden
The saw seems to be getting too much gas. with the filters off i can blow air in the carb and it does fine. i cleaned the needle valve and it does the same.
The carburetor could be set too rich for the unit to run properly. If you take it to a Stihl dealer they can tune the saw to the correct rpm. You can try to tune it to a "leaner" position. Look at the carburetor while it is on the unit and at Wide Open Throttle turn the H screw clockwise maybe half a turn and see if it will run at a higher rpm.
Alternatively you could re set the high side (Wide Open Throttle) by turning the screw until it seats (please turn the screw lightly as you could damage the seat) and turn it one full turn out. This is the factory setting and the unit should run O.K. at that position. If it still does not run correctly then there could be other issues with the carburetor that is making it not run very well.
Aug 18, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
Your carburetor needs cleaned or you need a carb. kit depending on how old the carb. parts are. If you need tips on carb. cleaning, feel free to ask.
Jim
May 30, 2009 | Echo Garden
Garden Logo
73 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
