Question about RCA Electronics - Others
I bought an RCA VHC145KITN Quad compression kit, and it was packed without instructions.
  • maiaw Mar 13, 2010
    the strip guage instructions for the RCA connector are about 1/2 way down that page
    RG-6/U is a common type of coaxial cable (electrical cable with an inner conductor surrounded by a tubular insulating layer typically of a flexible material with a high dielectric constant) used in a wide variety of residential and commercial applications. RG-6 (which originally stand for Radio Guide) is used to refer to coaxial cables with an 18 AWG center conductor and 75 ohm characteristic impedance. RG-6 has many specifications: F6TSSV, F6TSSVcu, F6TVS, F6TVScu, F660BV, F660BVcu, F660BVF,F660BVM, F690BV, F690BVcu, F690BVF, F690BVM maximum range.
    RCA Compression Connector is designed for terminating long RG6 coax cable runs, 6 color-coded bands included for field-configurable cable ID during installation.
    RG6 Coaxial Cable to RCA Compression Connector installation procedures:
    1. Using a 2-bladed stripping tool, strip the RG6coaxial cable exposing 0.25 inch of the center conductor and remove the 0.25 inch of the outer coaxial cable insulation.
    2. Fold the braid back over the outer coaxial cable insulation.
    3. Then carefully insert the coaxial cable into the RCA compression connector until firmly seated.
    4. Finally, using a proper tool, compress the connector.
Http://voxrightnow.custhelp.com/app/account/questions/detail/i_id/240045/kw/vhc145kitn/r_id/159
Posted on Oct 29, 2009
Why does my 250cc suzuki quad have no compression with a new top end?
If its a 2 stoke,"takes gas oil mix", piston in backwards,, ,,,,if its a 4 stroke "takes gas only"...rocker arms need adjusted, or cam not set in proper place during resembly "out of time". Or a. Bent valve/valves,,,in the head, valve will have to be replaced
May 06, 2014 | RTO Quads 125cc Full Size Adult 4 Wheelers...
I got a Little Tykes Junior Quad given to us and the lights, and all buttons on the front work fine. There is no power to the pedal though. Would it be that I need to replace the power pack? I know the...
You should have a battery charger to charge the 6v battery that powers the wheels, your first step should be to make sure this battery is fully charged, its located in a compartment under the seat.
Jan 01, 2011 | National Little Tikes Junior Quad
RCA HD56WW66 green light blinks three times then nothing
install the RCA repair kit called the CP50, CP120 and CP114 repair kit from www.tvrepairworld.com the kit also contains the instructions on Cd
Apr 14, 2010 | RCA HD56W66 56" HDTV
We have a large screen RCA model #R52WH73 TV. We bought it new about 2 years ago. Today when I turned it on...the picture looks concave and has shadows. Help?
the ITC222 and ITC222a Convergence option missing repair kit from www.tvrepairworld.com should solve that issue. The kit also contains the CD with instructions.
Apr 02, 2010 | RCA R52WH73 Projection Television
My tv looks like it is in 3D without 3D glasses, there are also some wavy color lines at the top of the screen
Most likely cause is FL231 and DL231 having failed. You can get the repair kit called ITC222 & ITC222A convergence repair kit from www.tvrepairworld.com which has the components and also includes the CD with instructions.
Mar 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
07 Kawasaki 650 Brute Force won't start
Seems like a non seating inlet (or exhaust) valve, the low compression and low mileage, plus backfiring points to this being a possible cause.
One other thing, if the quad has stood for a long time, a tight camshaft has caused a jumped timing belt to mess up the valve timing.
Good Luck - Curious to know what you find!
Oct 24, 2017 | Sport & Outdoor - Others
I have a RCA HDTV model R52WH77 and the picture is like watching a 3D movie without the 3D glasses.
The ITC222 and ITC222A convergence option missing repair kit should repair that issue. The kits available at www.tvrepairworld.com and contains the parts and the CD with instructions
Oct 14, 2009 | Televison & Video
We cant even get ours to power on.
Install the 270125 Flyback kit available at the following link. The kit contains the parts and detailed instructions.
Aug 13, 2009 | RCA HD52W59 HDTV Projection Television
Picture on 52 inchtv shows a dark picture
If you go in to the tv menu, you should find picture adjustments. You can adjust the contrast and brightness to fit her preference.
Please give good ratings, it is important to us..
Aug 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
T.v suddenly looks like 3d
Heres a repair kit that will usually repair that issue with the RCA rear projection TVs. The kit has the parts and instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-itc222-convergence-option-missing-repair-kit/cName/repair-kits
Jul 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Electronics - Others Logo
1,228 people viewed this question
Top RCA Electronics - Others Experts
rd2xpld
ray gallant
Are you a RCA Electronics - Other Expert? Answer questions, earn points and help others
