My total avoid points to date - Computers & Internet
I have a message on my phone and my Iphone each time I make a call they advice a phone number account is expired,i have de confirmation to my renewal 8/31/2015
Sadly there is absolutely nothing we here at FIXYA can do for you . this is between you and whatever phone service you have or had .
Nov 22, 2015 | magicJack Two, 2 Magic Jack Plus Voip...
How to reset date on royal cash register model alpha 710ml
Page 7
To set the date
1 At the prompt, use the rounded Number keys to enter the last 2 digits of
the year. For example, for 2006, press 06. Press the Amount Tend Total
<Enter> key.
2 Use the rounded Number keys to enter the 2 digits of the month. For
example, for February, press 02. Press the Amount Tend Total <Enter>
3 Use the rounded Number keys to enter the 2 digits of the day. For
example, 24. Press the Amount Tend Total <Enter> key.
4 Use the rounded Number keys to enter the 2 digit hour. For example,
09. Use military, or 24 hour, time for hours after 12 noon. For example,
if you want to enter 8pm, press 20. Press the Amount Tend Total
<Enter> key.
5 Use the rounded Number keys to enter the 2 digits of the minutes. For
example, 54. Press the Amount Tend Total <Enter> key.
Using the information in this example, the date and time are set to
02-24-06 8:54pm.
Sep 17, 2014 | Royal alpha 710ml thermal cash register,...
How to set time and date for mercury 130w etr
Prodeuce a z report 1st.
-Press vdmode untill displays 4...........
BLACK MACHINE>Press total.Press sh button then total (displays date).Press - *minus button.Key in current 180515 ddmmyy.Press stl twice.Proceed with time,press + *plus button.key in current time.eg1610.Press stl.Switch off machine.
Aug 18, 2013 | Boating
Program Group A is selected and the filter pump is programmed to start at 12 noon but does not turn on. If I start it manually, it runs fine and will turn off at the proper time. What could it be? ...
Check to see if your nine volt battery is good. The aqualink will hold it's programs but lose time and date. At that point it goes back to factory set. You have to have a fresh battery to avoid this.
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
How do I reboot my laptop so its like it was when it was new from the box?
There no such thing as a general reset. More than sure you are refering to Operating System than BIOS. One solution is to reinstall the Operating System and your laptop will be clean as new.... (software matter)
Nov 02, 2010 | Computers & Internet
My wii point icons jumps around
have you tried changing the sensitivity undersettings on the wii itself.
take a look at the link it will tell you how
also if you are to far away from the sensor it will jump.
Jan 06, 2010 | Nintendo Wii Console
CPU usage upto 99.99% in HP-UX (11.23 IA64). is there any patch
well. start first by minimizing your running programs,, maybe you have so much unwanted and unused programs, try removing some and check your unit again,, if not a total reformattting would help a lot ..
Nov 18, 2009 | Office Equipment & Supplies
How do I set the date on Sharp EL-1801Piii
Adjusting the tiome is just like adjusting the date, owith the only difference that you just enter two values (hours and minutes):
1. Move the Grand Total/ Rate Setting mode selector to the "Rate Set" "position
2. Enter the time in the orde of hour, minutes (use a point to separate the two values) and then presse the [Clock/Calendar] button to complete the entry.
You may also want to download the SHARP EL-1801PIII OPERATION MANUAL
May 15, 2009 | Sharp EL-1801P Calculator
Cant go back to created restore point
your pc probably automatically creates restore points and there is a limit on the space they can take so it automatically starts to remove the old ones.
to my experience system restore in xp was a total peace of ****
takeing up extra space and when used caused more problems than it fixed.
In my honest opinion system restore shouldnt be used.
Apr 28, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
