Videocon AC showed "E6" Error within 2 years of purchase. I wonder what had become the quality of the products. Any solutions ?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
Usually thermostat error or. Cooling fan
Posted on May 02, 2017
    Scholar:
  • 136 Answers
It could still be under warranty. Contact Videocon at www.videoconworld.com.
Posted on May 01, 2017
  • Siddharth Bothra May 02, 2017
    Videocon doesn't even respond to service query logged with them
  • 10 Answers
SOURCE: 2-year old unit. Cleaning quality has become
Clean your machine using White Vinegar
You can remove your spray arms and soak them in Vinegar to unblock them blowing out rubbish and unblock the small holes
Posted on Feb 24, 2010
icemelts
  • 246 Answers
SOURCE: I have purchase samsung Ac from Rathna Fanhouse -Chennai -
Assuming the ice is on the front of the unit it's a good bet that your inlet filter is dirty/clogged and is restricting the air over your evaporator coil. The first thing you need to do is turn off the unit and let the ice melt; in other words - 'defrost the AC.'
I would then try cleaning the filter (usually just needs to be washed out) but I'm betting you will need to clean the evaporator coil too.
Cleaning the evap coil is not that difficult, sometimes it can be as easy as pulling a 'sheet' of matted hair/wet dirt from the front of the evap coil.
Often you will need to use a brush of some sort and clean the coil. The object is to get the evap coil clear of all dirt so that air can flow easily through the coil.
good luck!
Posted on May 07, 2010
SOURCE: Videocon Split AC, Model VBS53
h6 problem create a machine showing a display?
Posted on Apr 26, 2015
  • 6702 Answers
SOURCE: Electrolux ac e6 error code Showing error code and then suddenly ac stops working Previouslt it showed e4 code similiarly but technician came and fixed it pls help Ac's brand new only 2 week old
When the technician already had to clear one error and within 2 weeks you should call again for another error, I would ask for a new one. It is supposed in warranty but still twice in 2 weeks is too much.
Don't try to solve it yourself. call the shop where you bought it.
Posted on May 05, 2015
hansonmg
  • 531 Answers
SOURCE: My videocon split ac showing on display e6 what is the problem
In this Videocon AC manual it suggests EEPROM communication failure. I don't know if this is your model because you didn't tell us what model you have. But the error could be the same no matter which model you have.
This error is internal to the control board so the only suggestion they have is to unplug the unit for 30 seconds and then plug it in again.
If you have the equipment to solder and a microscope or magnifying headset, you just might be able to see a bad solder joint and fix it if that's the problem. Otherwise you'll have to get a replacement control board.
https://videoconworld.com/media/gallery/for-vs5c3-vs3c3-vs6c3-vs5ch-part1.pdf
Page 10
Posted on Sep 16, 2016
Page 10
Sep 16, 2016 | Heating & Cooling
Meaning of e6 arrear Videocon split ac
Communication error between indoor to out door, Check the wiring from indoor to outdoor, if good, your PCB is faulty. Repair it.
Sep 12, 2015 | Heating & Cooling
What is E6 error in videocon ac and how to solve this problem plz ans me
Ok, so the e6 error generally occurs due to the lack of refrigerant. There are a few steps using which you can fix the problem that you are facing:
1. Look for the gas leak and fix that. Generally, the leaks happen from the coils which are mostly made out of copper or aluminum. Videocon mostly uses aluminum which is cheap but doesn't last long.
2. Get the refrigerant refilled.
3. Reset the control board in the indoor unit after fixing the issues with the outdoor unit and you're good to go.
You should consult a technician if things don't work out even after following these steps. In case you are looking for news ACs and other large electronics, visit GrabOn and get amazing deals on quality electronic items. Electronics Coupons Offers on Laptops TVs Tablets
May 26, 2015 | Computers & Internet
May 05, 2015 | Miscellaneous
ERROR E03 WHATS IS MEAN ON MY CONVERTER 600 WATTS ELIMINATOR
Hi, here is the error codes that I could find for you, it seems you are overloading the inverter. That means you cannot connect a kettle or other heavy load to the output. See all error codes below, hoep this helps.
Problem: The AC load will not operate, error code shows on digital
display and alarm is sounding.
Error Possible Cause Solution
E01 Low voltage shutdown because battery is discharged.
Recharge battery. Shorten cables or use heavier cables.
E02 Over-voltage shutdown because of high input voltage.
Verify the charging system is properly regulated and the battery
is 12 V nominal.
E03 The AC product(s) connected are rated at more than the
inverter's continuous power rating; overload shutdown has
occurred. Use a product with a power rating within the inverter's continuous power rating (see Table 3).
E04 The inverter has overheated due to poor ventilation.
Overheating shutdown has occurred.Turn inverter off and allow to cool for 15 minutes. Clear blocked fan or remove objects covering unit. Move the inverter to a cooler place. Reduce load if continuous
operation is required.
E05 The AC products connected have a surge power that exceeds
the Digital Inverter's surge capability or the AC products connected are short-circuited and shutdown has occurred.The products exceed the inverter's surge capability. Use a product with a starting surge power within the Digital Inverter's capability.
Nov 14, 2014 | Cameras
Videocon 21 est no
It should be a problem to its chroma IC. Check it.
Jul 22, 2013 | Televison & Video
VIDEOCON SPLIT AC SHOWS H6 & IS NOT WORKING
Videocon Air Conditioner Shows Error Of H6 Plz Tell Me The Solution.as urgent
Apr 16, 2013 | Heating & Cooling
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
Heating & Cooling Logo
220 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
