AR-M160 H4 Error code H4 flashes
AR-M160 cannot copy, it shows H4 Error code H4 flashes
5 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: H4 error code
Image Quility can be the "AE" botton in between the lighter and darker adjustment or it can be the text/photo botton. I'm not 100% sure which???? Try both to lock it in....
Posted on May 30, 2008
  • 32 Answers
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Posted on Mar 25, 2009
  • 118 Answers
SOURCE: Sharp AR-M450 is showing error code ''H4-00''
You're getting a heat roller low temp detection on the fuser in your copier. The fuser is the device that provides heat and pressure to the toner to bond/fuse it to the paper (it's that black, rectangular box in the upper part of the body when you open the left-hand side of the door).
Chances are a peice of paper is jammed up inside and blocking the sensor (probably a small peice that tore from a page someone tried to pull from the fuser). That or the temp sensor is defective.
Posted on Aug 21, 2009
  • 28 Answers
SOURCE: sharp ar-m160
enter the simulation mode:
"#" key Interrupt key "C" key Interrupt key
press 14 and START key
the copier should restart in most cases.
if not:
There is a problem in the fusing area, bad Thermistor, defective ThermalFuse, defective heating lamp.
Posted on Feb 05, 2010
Sharp AR-m150 refuse to copy, print and scan asking for user guide system error (H4-00)
error is sometimes a way for the machine to go into safe-mode when there is power fluctuations , or a problem with the machines thermistor or thermostat
Aug 04, 2013 | Sharp AR-M160 Black and White Copier
H4 error
H4 00 Heat roller low temperature detection
Press: "Clear", "Interupt", "0", "Interupt", "14", "Start Key"
Feb 26, 2013 | Sharp AR-M160 Laser Printer
AR-M150 shows h4 but it does'nt have interrupt key
There is need to solve the low current problem by simply rectifying it frfom the power supply.
enter simulation (use SIM14) 'C' 'auto' 'C' 14 copy key
Jul 16, 2011 | Sharp AR-M160 Black and White Copier
Error code H4 appear on display when voltage low in photo copier machine sharp AR-a61
in order press P * C * or # * C *. the machine will go into diagnostics. Then enter the number 14 as if making 14 copies. Then enter 1 and press start. That should reset your machine.
PLEASE let me know if this fixes it.
Aug 19, 2010 | Sharp AR-M160 Black and White Copier
AR-M160 Black and White Copier: it flashes H then 2 will not copy...
H2 means termistor damaged enter code 14 .if not solved change termistor
May 17, 2010 | Sharp AR-M160 Black and White Copier
Sharp ar-m160
if not:
Jan 26, 2010 | Sharp AR-M160 Laser Printer
My AR M160 digital imaging copier keeps blinking with 4H showing and I cleared the paper jam, all intact, and now nothing but the blinking 4H. please advise
H4 (and other) Error Reset Code:
Press "clear" "interrupt" "0" "interrupt" in succession and machine will blank off
Using the numeric keypad make the display read "14"
Press the "copy/start" key
Good Luck
Nov 09, 2009 | Sharp AR-M160 Black and White Copier
Oct 26, 2008 | Sharp AR-M160 Laser Printer
H4 error code
May 29, 2008 | Sharp AR-M205 Black and White Copier
Printer problem
Not too sure but might be that the fuser is not warming up as the sudden power loss caused the fuser lamp to blow if not then the control board has a fault.
Thanks J
Feb 25, 2007 | Sharp AR-M160 Laser Printer
81 people viewed this question
jasbo
jasbo
