Question about SWANN Cell Phones
Trying my cctv to mobile works on wifi when I turn to 3G and press play circles spin in middle for little while and then opening failed checked settings and all seems to be turn on its a Swann 4400
SOURCE: Iphone 3G Erase All content and settings problem
DFU means Device Firmware Update. If a restore using Recovery Mode doesn't work you will want to use DFU Mode as a last resort. When placing your iPhone into DFU Mode it does not load the OS before attempting the restore
videothumb.pngWatch the Video!
For your convenience this tutorial is available in video format also. Click the Watch It button to view the tutorial!
To put the iPhone into DFU mode so you can do an iTunes firmware restore follow these steps:
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black like this:
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
Posted on Aug 12, 2009
SOURCE: Can't use WiFi on Aino
Guys i foun a solution for the problem.
Just enable content sharing and in the connection setting window in the browser set allow local connection, and then it will use the wi-fi . cheers
Posted on Jun 20, 2010
  • 4 Answers
SOURCE: My Iphone 3G won't connect to home wifi.
you can try to set your wifi same as your husband's one, check the wep code and wifi shold be enabled.
try this and give feed back!
good luck
Posted on Jun 30, 2010
  • 55 Answers
SOURCE: I set up the WiFi
I think this will solve your problem. Try following the instructions given here.
Hope this helps! -jayps
Posted on Mar 09, 2011
SOURCE: Wi-Fi 3g
I need password so I can get free games on iPod
Posted on Nov 29, 2011
I got a message that i had run out of data. can this be the reason why i can't use my phone?
Usually if you get a message that you have run out of data, that is usually the case. You can check with your carrier and find out if you have in fact exceeded your data. Have you tried playing the game while connected to wifi? If you ca play it while on wifi and then turn off wifi and attempt to play the game while using your cell data, then your answer would more likely be that you have in fact run out of data.
Jun 08, 2016 | ALCATEL-LUCENT USA INC One Touch Fierce 4...
WhatsApp messages not coming through unless I open the App. Help!!!
you need unlimited data,it is an app,it is not programmed into your phone as a normal text message,it works well with wifi,but,when not near wifi,it needs to be on to use it.
Jun 18, 2015 | Samsung Galaxy S5 Mini G800H 3G 16GB White
Huawei problems
Check that you have a good wifi connection (or at least decent 3G/4G), and make sure you have updated the app.
Jul 15, 2014 | Huawei Ascend Y300 Mobile Phone
Wifi 3g on w755 ?
WiFi and 3G are different. W755 doesn't have WiFi. Check with your service provider about 3G where you reside.
Motorola Support
May 16, 2014 | Motorola Mobility MOTO W755 Cellular Phone
I had a samsung galaxy tab GT-P7300 , the problem is its a password protected and i have forgot the passwoed, so kinly help meout
  1. With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
Mar 07, 2014 | Samsung Galaxy Tab Tablet PC
I've used the internet but do not have free access, I know have a small blue icon at top of screen which looks like a 'blue dot with signal lines coming from it, which I cannot get to go away?! please...
Looks like your wifi is on and is set to the default internet option. Turn off the wifi first by going to the wifi icon in your menu and tapping the wifi circle in the middle.
To change the internet profile i.e. 3G go to menu/internet/settings/internet profiles and choose your preffered option, normally you will need to request internet settings from your network provider by sending a text.
The blue icon you speak of is tells you wifi is on this should go away once wifi is deactivated better to do this as wifi eats up the battery on this phone big time.
Mar 21, 2011 | Samsung Jet S8000 Cell Phone
Open the phone.
2. Press and hold [The button that has a phone on it with a little circle].
3. If necessary, enter the
PIN and press <OK>.
Switch off 1. Open the phone.
This will work unless its dead. Be sure to slide the phone open b4 trying to turn it off or on.
please mark this as fixya, and recommend me.
Nov 29, 2009 | Samsung SGH-G600 Cellular Phone
GPS not working
Try this -
1) Settings > Enable 3G Change to Off.
2) Use the iPhone GPS receiver to locate your position
3) Settings > Enable 3G change to On.
There are two positioning systems in the iPhone 3G, one is the 3G network, and the second is the GPS receiver. The problem occurs when the data from the two systems doesn't match.
Jul 14, 2008 | Apple iPhone 3G
Durabrand CD player skips while playing.
hi i've had the same problem i though it was the laser or the laser rail until i opened it!! Then i checked the laser, the rail and all the other mechanical it worked fine, until i got to the laser it had a hair right in the middle, don't bother trying the cd cleaner it doesn't work! all i di is take out the laser cleaned it with a cotton suabe and alochol for a bout a minute and now it works beautifaully! also clean the circle thingy that spins and holds the cd! any little particle will make that laser not read the cd right! while ur there tryin cleaning the unit from dust! it's the worst ememy! well hope this helps!
Feb 19, 2008 | Audio Players & Recorders
Cell Phones Logo
26 people viewed this question
Top SWANN Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a SWANN Cell Phone Expert? Answer questions, earn points and help others
