Question about Lands Phones
We have had our caravan serviced and now the motor mover (truma) does not work, we have changed the batteries in the handset. Is there a reset button or something.
3 Suggested Answers
  • 14036 Answers
SOURCE: Reset ''Service Vehicle'' message in 2005 Dodge Caravan
Posted on Oct 24, 2009
  • 1340 Answers
SOURCE: handset not working
This should reset your handset.The first parentheses has a phone symbol in it.
Press and hold [ ] and [#] for more than five seconds. Select DEREGISTER HS.
Select the handset which you are operating, and then press [menu/select].
The phone will ask you to confirm the deregistration. Select YES. The selected handset will clear its registration
information only from the base it is currently connected to, and then delete the link to the base from its own
When the base information is deleted, the handset displays HANDSET NOT REGISTERED-PLACE HANDSET
Re-register the handset to the base (see Registering accessory handsets on page 12).
If the handset cannot contact the base, it will display OUT OF RANGE. Make sure the handset is in range of the
base and the base is connected to power
Here is a link.It is not your exact handset but very similar.Many Makers use the same technology in newer models.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Greg Also,if this doesn't work,there are many ways which makers use to do this same thing,register a handset.
Posted on Nov 29, 2010
One handset is not responding and when pressed for long time the emergency alarm is turned on. Is there any reset button to troubleshoot this...?
remove battery for a few minutes and see if connections are clean- if when batteries are inserted and still have problem--- problem with mother
Jul 10, 2016 | Motorola MJ270R Two Way Radio
My door lock buttons dont work inside my mercedes s430
either the lock activators do not work, maybe the handset battery is dead? There is a small lock-activation motor in each door which opens and closes using the "lock" and "unlock" buttons on the handset, but if the circuit to the lock actuator is broken the motor will not work. Try disconnecting the battery under the hood. After disconnecting one post, wait 4 or 5 min and re-attach the battery cable and tighten...this will reset the auto's computer. Maybe that will work.
Jun 22, 2016 | Cars & Trucks
Truma motor mover S single axle problems
that is how a diff works
exactly what is the equipment ans what is the problem
what is a truma motor mover
Jun 24, 2017 | Televison & Video
Hell There, We have a "legacy" GE hands free kichen" phone model: 26730GE1-D Yes, I know it's ancient, BUT I did put a fresh, brand new battery in last week and it rings, when piucked up reads out...
The calls are being placed on waiting, try using Flash button before using Talk.
Test the chance on a different phone line , the most likely is that the phone is defective.
If the phone is working on a different line, then it is a configuration problem, and the phone is waiting for a manual call transfer from a different phone in your network.
Try using Flash button instead of Talk, this will answer the call if there is a waiting service programmed.
Try testing with no other phone connected.
Finally try resetting the phone, use procedure below:
  • 1. Make sure the phone power is ON (but not in the “talk” mode by pressing the PWR button.
  • 2. Use the arrow buttons to scroll through the main menu until Handset setup is flashing.
  • 3. Press the SELECT button. A second menu shows on the display.
  • 4. Use the arrow buttons to scroll to Reset phone.
  • 5. Press SELECT.
  • 6. Use the arrow buttons to change NO to YES.
  • 7. Press SELECT to confirm.
If after resetting the calls are still being placed on hold, then again, the phone may be faulty.
Here a manual for your phone.
Jan 15, 2010 | Cell Phones
I am unable to get the rollers to go on to the wheel also the motor does not run when buttons pressed. the relay unit has one red and one green light so there is power there supposed to be 2 green...
please explain what you are trying to do because iam intrigued ,rollers on the wheel?? Sounds like an old scammel truck with its funny trailor pick up system
Nov 10, 2009 | 2007 BMW 530xi Sports Wagon
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Aug 02, 2009 | Uniden DECT 6.0 Cordless Telephone...
Handset can not connect to base unit ATT E-2126
AT&T 2.4 cordlessE2126 handset will not reset to base
Apr 01, 2009 | AT&T E2126 2.4 GHz Cordless Phone
Please Help!!! I have IBM-3900SL cordless phone. Recently, I changed a battery, and it stopped working... When I try to use the phone, it keeps saying 'connecting...' and shut off by itself. Battery is...
You need to register the base and handset... Here is how to do it:
Press and hold the "CH" button on the right side of the handset and the press and hold the "Page/Find" button on the base.... The handset should say "Registered" in a few seconds
May 17, 2007 | IBM 2.4GHz Phone
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
