Question about Haier Televison & Video
Haier 50e3500 doesn't have backlight. Can't change brightness from 0
Anyone know if this is why it's so dim, or if by default, it won't allow you to change from 0 if the led drivers are bad? Installed new power supply thinking it was the problem. Don't have a remote, and not sure how to change led backlight brightness
map9966
  • 2351 Answers
SOURCE: Intel D865PERLL Motherboard will not power up
Hi nkda2000, this is as close as I could find for power schematics. Intel D865PERL
http://support.intel.com/support/motherboards/desktop/D865PERL/sb/CS-027143.htm
(There is no Intel D865PERLL board). Sure it's a typo. Have done searches for D865PERLL & found it (Not on Intle's web site) but when looking at the specs it's listed as D865PERL. (One L ) not two.
I hope the Technical Product Specification pdf can help you check the power on the motherboard.
Luck!
Mike
Posted on May 08, 2008
  • 124 Answers
SOURCE: location of headlights brights and dims
the inner lights are the brights but some vehicles also use the bright lamps with low voltage as the daytime running lights
Posted on Dec 05, 2008
  • 58 Answers
SOURCE: "Upgrade" of Backlight Panel
just replace what failed.
I replace the surface mount FETs on the inverters.
Posted on Dec 06, 2008
gsage
  • 180 Answers
SOURCE: hp laptop 9720us screen wont brighten or dim. last
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Posted on Aug 08, 2009
gopakumarg43
  • 75462 Answers
SOURCE: KDL55HX800 dims and then shuts off and red LED blinks 6 times
IIC bus clock and/or data lines low at power on 06
Posted on Aug 28, 2012
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
I cant grt the menues to come up? eather by the remoye or buttons on the front.
I have a similar problem the screen goes dim after the Haier welcome screen ? do you know of a fix ?
Thanks
Apr 08, 2012 | Haier HLTD7 7 in TVDVD Combo
My 6270 backlight when it suppose to turn on sometmes it doesn't or sometimes comes on dim. If I tap the side it comes up bright. I am familiar with trouble shooting circuit boards to a component...
Sound like u have loose Fiber Optic cables connections cables somewhere,if u tap the side of it comes back brightter.Take the unit aparts and tries reconnected all the Fiber Optic cables tightly if it work.Tries it out the unit turn it on/off 5 or 6 the backlight go up good and bright.Take hot glue gun glue all the Fiber Optic cables connections together for good.
Aug 11, 2011 | Ademco 6270 Graphic Touchscreen Touch...
How do i turn my kepboard light on?
Set the brightness of the backlighting
1. In the device options, click Screen/Keyboard.
2. Set the Backlight Brightness field.
3. Press the Menu key.
4. Click Save.
Set how long backlighting remains on
2. Set the Backlight Timeout field.
4. Click Save.
Stop backlighting from dimming automatically
2. Change the Automatically Dim Backlight field to Off.
4. Click Save.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 17, 2010 | RIM BlackBerry Pearl 8100
How do you turn on the Backlight on the screen?
If the screen backlight is not on, first try adjusting the brightness.
Press TV/AV button on remote to select TV mode. Press the MENU button on the remote. Using the arrow keys (navigation buttons), choose picture mode and adjust the brightness and contrast.
If your TV screen is still not lighting up in a dim room, then the backlight is broken.
You have 90 days labor and 1 year parts from date of purchase.
Oct 19, 2010 | Haier HLT71 7 in. Portable TV
Dark Screen even when i adjust the 'brightness' tab?
check the power settings on te unit, if it is set to default for the backlight, possible that your LCD's backlight is not powering up properly on the unit or LCD's backlight needs replacement.
Jun 03, 2010 | Apple iPod touch
My laptop, hp compaq nx6110 has a screen problem. Its dim
OS?
Check the "Power Options" in your "Control Panel" (classic view). For whatever option you have picked, click "Change plan settings". There you can either "Restore default settings", or manually "Change advanced settings". If you choose "advanced settings", look for "Display" / "Display brightness".
Feb 26, 2009 | HP Compaq nx6110 PC Laptop
Tocco backlight not staying on.
Menu > settings > display and light settings > light settings > backlight time > dim> change time till dim upto 3 mins. back >on >change time light stays on .
Jan 18, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Background lighting gone crazy
Ok, this problem is a game glitch, if you downloaded it from the internet, it may have some bugs or some glitches that screws up your phone. I suggest you go back to the shop and exchange a new phone because if it was only three days, the warranty is still valid. So go to the shop immediately.
Aug 20, 2007 | Sony Ericsson K800i Cellular Phone
Backlight not working
Did you try to set the Backlight on in the control panel? (settings>system>brightness) The brightness is often automatically set to 0. If you did this already and it still doesn't work, probably try an email.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Televison & Video Logo
107 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
