Question about Electrical Supplies
Why my ryobi 2200 backs down under load of a small refrigerator?
It runs perfectly under light loads like tv, lights etc,but when u turn on the refrigerator, it boils down and cuts off
    Sergeant:
  • 202 Answers
Try to balance your loads. Maybe you have to much load on one side.
Posted on May 02, 2017
Why my ryobi 2200 cant run a refrigerator?
The power demand of a refrigerator is too high for your 2200. You need something that can provide at least twice the power output of your 2200.
Semper Fi,
Z
May 01, 2017 | Ryobi Garden
Why does my Ryobi 2200 watt generator surge at low RPM's
The engine is not getting enough fuel. Try choking it some and see if this helps. If it does, then check the fuel filters. If you still have problems, then you will need to clean the carburetor or open the main jet if it is adjustable. Modern small engines are se to run as lean as possible to keep pollution down. This is much worse on small engines shipped to California. If the carburetor and filter are clean and you still have the problem, take the carburetor to lawn mower shop and see if they will replace the main jet with one a little larger.
Let me know if this gets you going. Robert
Nov 17, 2014 | Electrical Supplies
That sounds like dirty/clogged idle circuit passages in the carbureator. A little spary carb cleaner might work, but you might have to rebuild it.
Engine governor sensitivity may be set too high, it keeps correcting too much, it's typical for all generators, 1 KW - 1 mega watts units.
My husky 5k generator runs fine under light load (lights tv fridg...about 1500 watts) if i try to run one 8ft elelctric floor board heater (2500watta) with nothing else on the engin bogs down and speeds...
The rating of floor heater is 2500 watts, but how many amps are they pulling? Is the amp rating of heater higher than amp rating of generator? Just an idea. I have run into this on generators before as well.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Oct 01, 2013 | Electrical Supplies
My Impact 36LP runs fine under small load (lights/TV/Fridge), however when I turn on my RV A/C unit the generator slows and stops after about 2 minutes. JD
the generator is rated for a certain static load. it may also have an intermitent loading. when the critical load value is reached the engine slows down because the load is too much. add together all the wattages of your loads to get a final load in watts and check against the nameplate wattage of the generator.
Dec 22, 2010 | Electrical Supplies
Hi, i have a Honda ES 2200 7 years old, it supply grinders, drillingmachines, jigsaws etc without any problems, but lamps and other divices that uses less power, won`t start up ?
I think that your Honda has the so called "Automatic idle".
If the load falls under some minimal load (20 - 100 W) it automatically goes into it.
This option has to be cancelled or adjusted, in order to handle small loads.
Otherwise you should connect permanent load of 50 - 70 W in order to use your small consumers.
Jul 01, 2010 | Honda Electrical Supplies
No Brake Lights?!?
There is brake light switch located under the dash. It is inserted in a metal bracket that is a part of the brake pedal assembly. When you depress the brake pedal the pedal arm moves away from the brake switch allowing a spring loaded plunger to move out of the switch. As the plunger moves out of the switch a set of contacts close in the switch and turn the brake lights on.
You stated the 10amp under hood brake light fuse is good so check to see if you have power on the "orange" wire at the brake switch with pedal all the way up. Then press the pedal down and you should have power on the " light blue" wire going out of the switch.
We will start there, let me know what you find.
Regards,
May 01, 2009 | Saturn Vue Cars & Trucks
Panasonic PT53tw53-TV shuts down, red blinking light,
Replace diodes 6301,6116,6117. on G board.Diodes will sometimes read good but break down when under load.
Jan 06, 2009 | Sony KP-46WT520 46" Rear Projection...
Printer does not print
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Jan 11, 2007 | Canon PIXMA iP1600 Printer
Electrical Supplies Logo
43 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
