Question about Toro Garden
Location of electronic module
72 inch quick cut from toro
4 Suggested Answers
  • 6 Answers
SOURCE: looking for drive belt installation instructions
type toro manuals,and it will get u a site
Posted on Mar 20, 2009
  • 54 Answers
SOURCE: toro 1991 42 inch mower doesnt cut even how do i
The blades should be a simple bolt on, how ever there are no adjustments at the blade. Your adjustments are on the swing brackets that raise and lower the deck.
Posted on Apr 28, 2010
SOURCE: groundsmaster 72
Im missing the drive too. from moter flywheel to pump ..
Posted on Jul 07, 2010
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
Aug 30, 2012 | Toro& Electric String Trimmer
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
10 year old Toro 2017 lawnmower, suddenly stopped while cutting grass. Oil quite low. Cannot pull cord more l than few inches.
When you pull the cord does it hit a hard stop and not go any further or does it get really difficult?
Aug 02, 2011 | Toro Lawn Mower With Toro Power Tools
Toro 1991 42 inch mower doesnt cut even how do i
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Why does my toshiba 72 inch projection tv picture freeze?
sounds like your dmd module. its the part of your optical block that processes the images that make up what is projected on your screen.. without a model # i can't tell you the part #
Mar 13, 2009 | LG Televison & Video
Groundsmaster 72
Have a toro groundmaster 72 that the spline went out in the power drive adaptor. the part is not avaible from toro.21-2260
Aug 30, 2008 | Garden
Garden Logo
23 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
