Question about John Deere Garden
Where is the carburetor located on a JOHN DEERE LT150?
My john deere LT150 won't turn over, it backfires as it turns. smoke comes from the exhaust as well during starting..
  • John Deere Master
  • 7,515 Answers
If you want to solve your problem, click on the link I attach.
JOHN DEERE LT150 LT160 LT170 LT180 LAWN GARDEN TRACTOR Service Repair...
Posted on May 16, 2017
Gas is leaking into my oil causing it to smoke and eventually stop, john deere la 135 series
it needs a new needle and seat in the carburetor. just buy a kit. it will have everything needed to rebuild the carburetor.
Apr 19, 2018 | John Deere Garden
How do you adjust a john deere 160 FC420V carburetor. It just backfires out of the carburetor and don't start
Hmmmm. Backfiring is usually a function of bad timing. Or check to make sure that the float is working and that the engine is not being flooded with gas.
Sep 09, 2017 | John Deere Garden
Model LT150. Why won't blades engage?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Oct 20, 2015 | John Deere Garden
Got new brakes and now the hubs won't turn
You need to adjust the slack adjusters
Jan 31, 2013 | John Deere Garden
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
My lt150 lawn tractor is backfiring when the pto is engaged and cuts off in about a min of use, but it runs fine without the pto on.We have drained the gas and put in new gas, and cleaned out the...
Sounds like the float is bad - what happens is the float sits just a little off and when you add the demand of more fuel it skewers the RPM by starving the engine.
Try removing the carburator and either adjusting the float by bending the tab or replace it. As part of this repair i suggest you just replace the needle and seat as well if they are over a year old.
Thanks,
Gary @ Fix Ya
Jul 22, 2010 | John Deere Garden
John deere 425 lawn tractor. it wont start but it has spark and fuel the starter engages and the fly wheel turns
If your tractor has an anti back fire solenoid in the front of the carburetor then it should start if you remove it and cap it off with a pipe plug.It should run if the solenoid is the problem,if so you really should replace it but if it is'nt prone to backfiring with it remove you don't have to.You may also have a bad seat switch,confirm this by jumping the plug with a piece of wire to temporarily test it.
Jan 14, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
108 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
