Cannot receive all channels - Televison & Video
I CAN ONLY RECEIVE 2 OR 3 RADIO CHANNELS ON MY INSIGNIA RECEIVER
Radio tuners receiving AM and FM channels/broadcast MUST have some sort of antenna connection. For local channels a paper clip will work, but for more distant channels, use either a better inside antenna or purchase a outside antenna as needed.
Jan 30, 2013 | Insignia 200W Stereo Receiver
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
Receiving channels
tried to save those channel in the memory.
Jul 27, 2012 | Insignia Televison & Video
Channel lock is stuck on
May 28, 2011 | Televison & Video
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Satelite receiver stuck on one channel.
Go to the menu settings. See if there is an option for 'autoprogramming" It should search all available channels.
May 28, 2009 | Televison & Video
Recording 3 digit channels
With the VCR connected to DirecTV, you're not picking the channel with the VCR anymore. You're picking the channel on the DirecTV receiver, and the VCR will record on channel 3 or 4 (if you've hooked the receiver up using the RF output to the VCR) or through its line (A/V) inputs if you're using those. The tuning range of the VCR is completely unimportant.
With your new system, though, there's one big drawback. Since the VCR is always set for channel 3 or 4, or its line input, and you're changing channels on the DirecTV receiver, you can't program the VCR to record several different channels if you go out. You won't be home to change channels on the receiver, so the only channel you'll be able to record is whichever one you've selected before you go out. Remember the VCR is taping the output of the satellite receiver, and not the satellite channel directly. If you record on some channel other than the receiver's output channel, there won't be anything there. All you'll get is snow or a blank screen.
Mar 31, 2009 | RCA VR706HF VHS VCR
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
I have pioneer receiver Vsx-454 i want to know if this receiver is 5.1 surrounds
Yes. It is 5.1 surround. There are 2 front channels, 1 center channel, and 2 rear channels which comprise the "5" in 5.1 surround. The pre-amp output channel for a sub is the ".5".
Jan 11, 2009 | Pioneer VSX-454 Receiver
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
