Question about Teac Audio Players & Recorders
Cd player does not seem to recognise a CD. it closes, does not lift the CD to engage and then reopens again. If i insisted it eventually used to play at the fifth or sixth attempt but now it will not.
This is a TEAC H500C
  • Teac Master
  • 5,484 Answers
This could be dirt or damage to the lazer lens. But you should carefully look at the plastic parts of the mechanism just to make certain there is no damage to anything.
Posted on May 03, 2017
  • 1153 Answers
SOURCE: Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Posted on Oct 08, 2007
SOURCE: Not Recognising a CD
I got a second hand 541 a few weeks ago. After many hours of listening pleasure an no problems at all, the machine stopped spinning CD's, both copied ones and original ones.
The sollution for my problem was simple after some figuring out.
Open the CD tray.
Power off the unit with the tray open.
Open it up.
In the CD frame in the back there are 2 srews that hold the CD engine unit in place. I untidied these screws just a little bit.
I also untidied the screws that hold the cd clamp cover on the top a little.
After this it loads all my CD's fine again.
Posted on Feb 28, 2008
VOTIT
  • 2071 Answers
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
Posted on Jun 18, 2008
  • 192 Answers
SOURCE: why does it say hold on my cd player when its closed ?
There is a "hold" button on the device that works like a key lock on your cell phone.
Find the hold button and switch it to the other position and you will be able to use your device normally.
Once you have put your CD player in a mode that you want, then you switch the hold button on so that you won't accidentally hit any buttons. You can then safely put the CD player in a pocket and not have to worry about it.
I hope this helps.
Posted on Aug 24, 2009
localwonder
  • 6784 Answers
SOURCE: Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Posted on Sep 14, 2009
I have a Sharper Image Blue Night CD Player with a motorized CD cover that automatically slides up or down (to play CD) at the touch of a button. When I push the button to close the door (and play CD),...
I would first check to see if there is something that is obstructing the door, and if you cannot find anything, then you could take it to any electrical repair shop, and they could fix it for you.
Mar 26, 2011 | Audio Players & Recorders
Sep 14, 2009 | Teac CD-P1250 CD Player
I am not able to install it.The windows is recognising the LG player.
Hey,
Cd and dvd drives are installed automatically on windows when they are connected properly. if your drive is not installing then your computers windows has problems, I would insist that you use recovery cd's to restore the computer to original state or use the windows installation cd to install windows to the computer again.
Note that the cd / dvd drive may work outside of windows, so you may be able to install windows with the drive even though it doesn't work in windows. check bios if the drive is detected there or not.
heres some info on the bios, how to get there and how to use it.
http://www.youtube.com/watch?v=Tc1t3c5Yke8
you may need to change the boot order so that the cd starts before the hard drive.
May 05, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Electronic repair
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
41 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
