Question about John Deere Garden
I have a John Deere GT225. The hydrostatic drive
I have a John Deere GT225. The hydrostatic drive just suddenly quit. I had just backed it up,shut it off,took the trailer off,got back on & started it up but it wouldn't go forward or reverse. Fluid levels are fine. There had been no clutch chatter or lurching to give any indication of trouble. HELP! I need my tractor back.
  • 1 more comment
  • Michael Byrnes
    Michael Byrnes Jul 25, 2009
    Thanks I'll check that in the morning.
  • Michael Byrnes
    Michael Byrnes Jul 31, 2009
    Thanks for your input, but I found it was the traction drive belt. It's running like a Deere again.
  • Anonymous Mar 30, 2014
    clutch wont disingage
Had same thing happen to my gt225. The drive pulley nut had loosened allowing splined pulley to strip on shaft. A new pulley may solve the problem of the shaft splines are ok. My JD guy said to get a new pulley and if it slips to tack weld it on. He thought new pulley would work. I did not find the problem until I took the other tranny out and I already had a replacement, so the old tranny less a new pulley is sitting on the shelf!
Posted on Oct 31, 2014
  • 112 Answers
Sounds like your linkage is disconnected, With the tractor off raise the seat and back panel (if possible) and work the shift and look for failing linkage.
Posted on Jul 25, 2009
Mower blades move but no gears forward or back, very suddenly quit.
Rex, check the drive belt,old stretched, loose, broke, fell out of position Tension er weak or seized if equipped, worn out pulleys.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tightening the belt on John Deere L110 Tractor
https://jdagccc.custhelp.com/app/answers/detail/a_id/428/~/mower-belt-comes-off---100-series
How to Adjust John Deere Drive Belt
John Deere Fail LA145
Apr 23, 2016 | John Deere L100 Series
Where would we get as manual for the d170 john deere grass bagger
Try this link to Deere customer support:
http://manuals.deere.com/cceomview/OMM167392_B2/Output/Index.html?tM=HO
If that's not your model, look around - they do seem to have quite a few manuals online, and offer to sell you a paper copy if they don't have an online version. Good luck!
Aug 08, 2014 | John Deere Riding Lawn Mower. D170 54 in....
John deere ride on problems
Black smoke indicates rich mixture. Dirty air filter. choke stuck on. loose main jet in carby. just a few possibilities.
Dec 31, 2012 | Oregon Scientific Oregon Gator Mulcher 3N1...
My John deere l118 riding mower goes slower and slower. suggestions please
Firstly remove the battery and battery tray and clean all grass and debris from around the hydrostatic drive and cooling fan. Secondly check the drive belt idler pulley, arm and spring for free travel. Hope this helps, regards Phil.
Jun 18, 2011 | John Deere 22HP Hydrostatic 42" Riding...
I have a john deere 316, the other day i was moving snow with it and all of the sudden it lost all power to the hydrostatic and to the front end quick attach. I was wonder what would cause this and how to...
First check level of hydraulic oil. Sight plastic tube just above and to the right of the hitch. Should be in the middle of the tube.
How long since you changed the hydrostatic oil filter under the seat deck?
Next see if the small splined shaft is turning btween the seat deck and the transaxle from the rear of the tractor. If not, it sheered a key in the hydrostatic drive shaft from the motor to the drive. (Had this happen to me)
Check the lever under the right side fender that disables the hydrostatic transmission to allow the tractor to to be moved without dragging the wheels. Make sure its not in the wrong position.
If all these are ok then the hydrostatic pump has failed.
Jan 01, 2011 | John Deere 420,1020,2010,2020,2510,2520...
My 4210 4x4 with hydrostatic drive quit driving runs well but will not travel forward or reverse
Hi, the engine will power the hydrostatic drive via a drive belt. See that this belt is in place or if it is worn out and loose. By replacing this belt you should get your machine running again. Hope this helps
Nov 17, 2010 | John Deere Seat 4210 4310 4410 4510 4610...
John deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Jun 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere CR125 hydrostatic mower, engine runs
sounds like you have carb problems
Sep 07, 2009 | Garden
Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Jul 12, 2009 | Garden
Garden Logo
820 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
