Didn't get it printed... - Office Equipment & Supplies
I have a PIXMA iP4300 and just want to use it for black and white document printing. My 'M' and 'C' color cartridges ran out a while ago and I disposed of them but didn't replace them...
Most of the Canon printers form the PIXMA iP series block printing when one of the cartridges is empty. You have some options: 1) change the cartridges (with original or compatible) 2) buy a chip resetter and reset the empty cartridges chip so they can cheat the printer that they are full. This way you will clog the nozzles of your print head and the printer will become useless and won't print.
That's why I suggest you to but even cheap compatible cartridges and replace them.
Hope this helps. Alex
Sep 11, 2011 | Canon Office Equipment & Supplies
I want to print using my lexmark X6170 but I don't want to print color so I didn't put a color cartridge in. It keeps coming up with an error message and won't print at all.
Some printers require you to have the color cartridges in them even when you are printing black and white. You usually can in your print options choose black and white over color.
Sep 03, 2011 | Office Equipment & Supplies
HI! The user manual print is so small. Is there a way you could email me a larger print or somewhere I can find it on the web?
Since you didn't tell us the make and model of your camera, the only help we can give is to suggest using a magnifying glass to read the print.
Jul 22, 2011 | Cameras
All of a sudden the printer stopped printing in color. We changed the lowest color cartridge (still has 10% on it, according to the online page for the printer), and that didn't help. The online page...
It seems to me a logical problem. Not hardware. Wich software are you using to print? CorelDraw? If so, in the miscelaneous tab in the printing settings (ctrl+e), check if the option "bitmap output" is not in the "grey scale" mode.
Jul 20, 2011 | Dell 5100cn Laser Printer
How do you print a picture from the computer?
Assuming you already have the printer hooked up and installed, cause you didn't mention how to install it, just open the picture you want to print in Paint (windows) Or Acorn (Mac OSX) and File -> Print. You could also right click on the picture and click Print.
Hope this helps, Nathan Taylor
(Don't forget to rate)
Jul 19, 2011 | Brother MFC-5460CN InkJet Printer
My lexmark x1290 printer will not print firstly it said it was the spooler stopping it i fixed that however now it is saying that error 0x00000006 i stopping it from text printing i am running windows...
This looks like either you do not have correct drivers, or that the drivers didn't install or didn't install properly Double check that you have the proper drivers. If you do, try reinstalling them.
Jul 05, 2011 | Computers & Internet
There are thin lines through my printed image - about 1cm apart - as if the ink didn't print on that area.
Inkjet printer?
Likely to be clogged print nozzles, run the head cleaning utility a few times, if that fails to work, replace cartridges and before doing so, swab the print heads with inkjet cleaning solution
Jun 20, 2011 | HP Office Equipment & Supplies
Lexmark X75 won't print in color. Tried cleaning print heads, didn't work. What now?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 16, 2011 | Lexmark X75 All-In-One InkJet Printer
I tried to print a route map from MapQuest, but it didn't print. I tried to cancel the printing, but it's been deleting since yesterday and been blocking any other document I tried to print
Restart both your printer and your computer. It might finish the print job after you restart the printer and yes it will block any other print jobs.
May 26, 2011 | Office Equipment & Supplies
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
