Question about Cameras
My Piranhamax 230 fish finder won't turn on. I've got new batteries in it and I've cleaned the contacts. Still nothing. Can you help
  • Cameras Master
  • 5,077 Answers
What kind of camera finds fish ? Methinks you may have posted this query in the wrong forum.
Posted on May 02, 2017
Depth finder turns itself off after i turn it on
only suggestions
needs new battery
malfunction of the computer
Mar 16, 2016 | Humminbird PiranhaMAX 143
My piranhamax 197c wont display fish in a pond? What could be some fixes?
this fish finder is for use in water up to 600 feet deep , a pond is most likely shallow , 1-6 feet , this im sure was not what the designers had in mind when making this
so as impractical as this sounds the fix is to deepen pond , id say it wouldn't work to less than ten feet deep
now humming bird does make one that is for shallow water (3-10 feet) (has a special transducer ) but that's not model 197c
May 27, 2015 | Garden
With the 190c on i hear a clicking sound coming from the transducer all the time it gets pretty annoying
Hi, unfortunately this is normal. Mine drives me nuts till I turn the stereo up! Sorry Phil.
Aug 28, 2011 | Humminbird PiranhaMax 190C Fish Finder ()
The depth reads 98 to 100 feet.
I need more details about the problem you are having to be able to help you.
My best guess is that your unit will only disply data between 98 and 100 feet?
If thats the case check the range setting on your unit. It may be set to only display that range. You can set it to auto and it will automatically adjust the range from zero to just over the maximum depth it is currently reading.
May 23, 2011 | Humminbird PiranhaMax 190C Fish Finder ()
Turns off
The first thing you need to check is if you have sufficient power going to the fishfinder. Take a multimeter and measure the dc voltage going to the display when the unit is off and also on. If this is below 12 vdc this is your problem. You will need to check for loose connections and possibly replace your battery.
If the voltage is good then the problem lies within the display. Unfortunately, you would have to contact Humminbird directly to return the display for repair or purchase a new fishfinder.
Jun 29, 2010 | Humminbird 161 Gps Fish Finder Combo
Gain failure
If you are 'testing' the unit by holding the right button and pressing power, the pmax units really don’t work with the internal test. What you are seeing in the test is what th humminbird factory computer test used to test it. That is really not intended to be used outside of the plant. If it works fine in normal mode then I would say that the unit is fine.
Best of luck!
Mike
Jun 28, 2009 | Humminbird Piranhamax 220 Fishfinder
Need the directions to wiring the humminbird fish finder piranha max 210
Wiring should be very straightforward, the connector on the left (looking at the back of the sounder) is the plug for the transducer, the 2 pin plug in the middle is for the power (notch in the plug cord points UP), and the 4 pin connector is for the optional speed and/or temperature sensor. Here is an install manual for your reference:
http://www.humminbird.com/PDF/Piranha1_2_IN.pdf
Mar 15, 2009 | Humminbird Fishfinder, Piranhamax 210 Pt...
Cameras Logo
54 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
