Question about The Audio Players & Recorders
My clock has no display since i changed the batteries
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 43 Answers
Try different batteries and make sure the battery orientation is correct.
Posted on May 01, 2017
Sangean h2o1 clock is flashing. The radio display doesn't flash - only the clock. I've reset the clock, changed the batteries, and generally played with the other settings. Can't figure out why the time...
Here's the thing: When you change the batteries, the radio thinks you need to reset the time, even though the time has been preserved and is correct even after you change the batteries. Here's what you do: Pretend you need to reset the time. With the radio off (recommended), press and hold the "Band" button with the "set" notation underneath it. The hour will flash. "Reset" the hour by using the tuning buttons, as you would if the radio were new, and then change it back to the correct hour. Press the "Band" button again and repeat the process for the flashing minute display. Press "Band" again to end the process. You will have successfully fooled the H201 into thinking that you have reset the time, and the time display will have stopped flashing. (This does not appear to work if you do not actually pretend to change the hour and minute and just keep pressing the "Band" button -- you have to go through the procedure as though you were actually changing the time.)
Aug 31, 2010 | Sangean H201 AM/FM Radio
Sharper Image Alarm Clock won't reset after changing battery
  • https://www.sharperimage.com/si/pdf/manuals/204050.pdf
Jan 06, 2018 | Audio Players & Recorders
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
Changed batteries
Also,
Sep 07, 2008 | SkyScan 86709 Atomic Wall Clock
OUTDOOR TEMPERATURE
Also,
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
Numerical time versus clock icon on the status bar
touch the clock icon and hold it down. A menu will pop up. Select digital.
May 07, 2008 | Palm Treo 700w Smartphone
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
for more than 2 seconds.
The hour digits start flashing on the
display.
2 Press 4 or ¢ to adjust
the hour, then press
PROGRAM/SET.
The minute digits start flashing on the
display.
3 Press 4 or ¢ to adjust
the minute, then press
PROGRAM/SET.
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
Press DISPLAY.
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
I have a87900 model skyscan,can;t get it reset after replacing batteries
Just did this after problem resetting after changing batteries, press setover and again til it displays est, then press+until your time zone is displayed, it will also display dst, press +till on/or off depending on your location, then US will appear, clock will then set itself. Good luck, how frustrating.
Dec 17, 2007 | SkyScan 86742 Digital Atomic Wall Clock
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
32 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
