Question about Exercise & Fitness
I am new here. My Sole E95 Elyptical makes noise when it is turned on. It doesn't seem to be related to moving parts but is coming from the control panel. Any thoughts?
Master_Tech
  • 770 Answers
SOURCE: noise
this fan is a variable speed and is controlled by a board in the rear of the unit. your bearings maybe going out. The fan will ramp up to speed depending on the call for cooling the Thermistors is asking for
Posted on May 20, 2008
  • 2920 Answers
SOURCE: Engine Skipping, emmission issue?
check the catalytic converter first...it will make it sputter
Posted on Aug 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a GE Profile Spacemaker XL 1800 JVM1860SD
That would be a defective electrolytic on the control circuit board.
We see and repair this problem often with our $39.95 service. Details are here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Jul 09, 2011
SOURCE: quad is charged but will
I have a dirt quad exhibiting the exact same symptoms previously described. I ordered a new controller and replaced it. The quad is making the exact same noise and did not resolve the problem. I tested the motor wire with my volt meter which registered approx 10-11 volts before the controller made a clicking noise and immediately the voltage drops to 0. I'm curious as to whether it may be the throttle?? I'm frustrated at this point. I tested the battery and it reads 24.6 V on the meter. Any ideas??
Posted on Nov 27, 2011
markhandyman
  • 44 Answers
SOURCE: blade doesn't move (reciprocate)
The drive shaft for the blade is stripped or broken. take it back where you bought it.
Posted on Oct 31, 2012
Sole E95 is stuck in highest incline
You have to hold the start and incline up buttons down for at least 5 seconds. If you did that properly and nothing at all happened then you have a pretty expensive problem on your hands.
Aug 02, 2017 | Exercise & Fitness
My Sole E95 has a clicking noise when it is turned on. It is not from the flywheel or any moving parts but seems to be coming from the control panel. Any thoughts?
Does the noise happen when the car is moving or all of the time? Is everything but the engine turned off (ventilation system)?
May 01, 2017 | Cars & Trucks
Hi I have a 2000 isuzu kb 2.8 td. The pulley on my crank seems to be in 3 parts and sometimes when i turn sharp or when the engine is cold it will make a screeching noise. I made marks on all three and i...
I would advise replacing the harmonic balancer asap. If the marks are moving then the bonded rubber which is the movement for the harmonics is coming apart and if not replaced will fail with possible radiator. timing cover and other related damage. I have seen one come apart on a Chrysler valiant and it hit the ground and went through a windscreen. The screech is the outer pulley slipping on the crank hub.
Apr 25, 2013 | Cars & Trucks
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
Dec 17, 2012 | RTO Sole Fitness Package F85 Treadmill &...
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
Operating manual sole e35
go to www.iconservice.com for free download
or http://fitness.manualsonline.com
Good luck,sincerely. G-d bless you
ERNESTO CUADRA
MANAGUA,NICARAGUA
Dec 12, 2011 | RTO Sole Fitness Package F85 Treadmill &...
SOLE E95 "Ramp Error" Message
Thanks! It was the calibration!
But in order to get to calibration mode I had to press "Resistance Up" and "Start", not "Incline Up" and "Start"
Aug 07, 2011 | Exercise & Fitness
Exercise & Fitness Logo
35 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
