Question about Home Security
Can't find keys or combination - Home Security
I have sentry safe ,lost key but I know the combination i have sentery safe wthih combination lock but i do not have key ,i do have combination. how can open the safe
Put the combination in and open the door. You only need the key if the battery goes flat.
You can get a new key here
Key Replacement
How to open without a key
open sentry safe without key Google Search
This kid shows you how to open one by bouncing it on a bed! If it is fixed, you hit it with a rubber mallet on top.
How to open digital safe without any tools or keys IN 2 SECONDS
Feb 18, 2018 | Sentry Home Security
Sentry safe 1250 lost combination
I have a sentry safe 1250 .83 cubic and I have the key I was using the safe for awhile without the combination and just the key but now the key wont work and someone messed with the combination part which I dont know the combination i dont know what to do and I dont wanna trash this safe
Dec 12, 2017 | Sentry Home Security
Can u assist me with opening my safe
Our tech team at Quality gun safes wall safes and floor safes store in Burlingame Ca produced this video
Nov 04, 2014 | Sentry Fireproof Safe
V332 combination insruction
Try this:
http://www.1stvision.com/cameras/IDS/dataman/uEye_User_Manual.pdf
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Jan 22, 2013 | Home Security
Key combinations to rotate screen
Deirdre,
The key combination to rotate the screen back to normal is: Ctrl+Alt+Up Arrow
If you use Ctrl+Alt+Arrow keys - whichever arrow key you press is the direction that the screen should rotate.
Hope that helps!
Nov 20, 2011 | Compaq Presario CQ61-310US Laptop
Keyless remote stopped working, I replaced battery
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and remote setup with a separate remote fob. However, the 2004 to 2009 Dodge Caravan and Grand Caravan use a combination key and remote on one device. To program a new keyless entry remote for the 1997 to 2003 Dodge Caravan, you must have at least one functional remote, which is required to enter synchronization mode. To program the combination key for the 2004 to 2009 Dodge Caravan, you must have two functional combination keys. If you do not, you'll need to see an authorized Dodge dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
  1. Insert one of your working combination keys into the ignition. Turn it to "On"; leave it in this position for about 10 seconds but no longer than 15 seconds. Turn it to "Off" and remove it.
  2. Insert your second working combination key into the ignition within 15 seconds of removing the previous key. Turn it to "On". After 10 seconds, you'll hear a chime and the "Theft" light will begin to flash, entering synchronization mode. Turn the key to "Off" and remove it.
  3. Insert the combination key you want to program. Turn it to "On." After 10 seconds, you'll hear a chime; then the "Theft" light will turn off. When the light turns off, the combination key--including the key and the remote--is programmed.
  4. Repeat Step Three for each combination key you want to program. A total of eight can be programmed.
Hope this help (remember comment and rated).
May 08, 2010 | 2008 Dodge Grand Caravan
Can't open sentry v260 safe
Make sure you are inserting key so the round hump on key matches red dot on lock, and turn key clockwise.
If that doesn't fix it, SentrySafe's support number is 1-800-828-1438.
I would think they can confirm the combination from your serial number. They probably won't give you the combination without a notarized letter, but if you have the right combination for that serial number safe, they may confirm that you are entering the right combination.
Be aware the 4 number combination V260's are changeable and if you HAVE changed it, you are on your own, they can't help you. The 3 number combinations are not changeable.
Mar 16, 2009 | Sentry Fireproof Safe
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
