Question about Element Televison & Video
Element FLX 3211B model audio at maximum 100 for volume but not loud enough
    Top Expert:
  • Element Master
  • 75,017 Answers
Sounds like main system control memory IC fault. Try a hard reset first. If it do not help; check and replace the main system control IC. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on May 02, 2017
Have pic but no is element model flx 3711-b
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Dec 20, 2014 | Element Electronics FLX-3211B 32 in. LCD...
Connecting computer to Element flx-3211b via HDMI not working
I had the same issue with this TV in my hotel room. I set the FLX3211B TV up as an extension of my laptop, but had to change the refresh rate from the default 58p Hz to 60p Hz for the digital TV display. Once I did this, it came right up.
Feb 26, 2013 | Element Electronics FLX-3211B 32 in. LCD...
Looking for the location of the Inverter Board in my Element Electronic FLX 3211B LCD Television Set. Is there a youtube video on how to locate and replace one ?or a photo that shows where it is.
What I have found on this tv is the inverter board is integrated with power board you might want to head over to badcaps site on this one.It could be as simple as replacing 2 transistors and a fuse.
Sep 01, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Hi my name is Oscar I have a tv element model FLX-3211B and do not work the remote control codes sony RM-VZ320 and need help please!
Please reset the codes and try again. You must replace the batteries by new ones type alkaline b) clean the contacts batteries c) retight the spring contacts batteries with pliers d) open the remote control for clena the keypad switch from dirty, dust, oxide, bad contacts or open , remember they send infrared signal from Syscon to the microncontroler Receiver. see the blck..d
go to the next web pages, give your model, mark. +
God bless you
Jul 29, 2012 | Sony RM-VZ320 Remote Control
Lost the screws for the stand, need the specific screw
Just called the Element Parts Department because I had the same problem.
M5 x 18 mm
Enjoy your properly secured TV!
Mar 15, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Element FLX 3211B has no power after 14 months of use. TV will not power on. Checked th fuse near the power cord and the fuse is good. There is no power going to the TV. Tested the power cord and it is...
Took it to a TV repair shop and they did the following:
1. Rebuilt Power Supply
2. Replaced Diode
3. Replacd Transitor
Total cost was ~$100. Tv works fine now.
Mar 13, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Televison & Video Logo
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
