Question about Bose MediaMate Computer Speakers
Unplugged speakers, plugged em in -- now I don't get ANY sound
My girlfriend unplugged my PC speakers for her iPod, then plugged em back in. Now there's no sound. They are powered up (power light is on), plugged in the right port (same one as always), and aren't muted. To make matters worse, now my headphones won't even play sound when plugged directly into the PC headphone jack! What happened?
  • camerondayto Jul 25, 2009
    What should I be looking for? My sound drivers are all up to date. Why would my sound go out with a simple unplug/replug of the speakers? Any chance this could have knocked my soundcard or something?
    President:
  • 392 Answers
Check ur sound drivers.. check whether they are uninstalled, and try to check in the sound and audio devices in control panel...
Posted on Jul 25, 2009
  • M.Jeevan Chaitanya
    M.Jeevan Chaitanya Jul 25, 2009
    May be it is possible..... because the output power is different for both the devices..
Lost my sound when I moved my computer
Have you checked speakers on another computer. Get it checked first if it working on another computer or other device. If it working reinstall realteK audio drivers.
Nov 04, 2017 | eMachines ET1810-01 PC Desktop
The icon for my Harman Kardon speakers completely disappeared from my desktop. No there is absolutely no sound
Are the speakers plugged in, turned on?
Restart the PC.
Unplug the speakers from the PC and plug them back in.
Unplug the power from the speakers and plug them back in.
May 06, 2011 | Harman Kardon HK206 Computer Speakers
No sound
1. check the power, is the LED indicator light when you turn on the power?
2. assuming the power is ok, unplug the phone plug from the computer, plug it to an ipod or any mp3 player's phone jack, still no sound? here are the possible causes:
a) broken internal copper conductor from the phone plug, b) busted amplifier chip
if you have basic electronics knowledge, these multimedia speakers are easy to repair, otherwise replace the whole unit. ;-)
Feb 07, 2011 | Logitech S150 2 Speakers
Power in amp but no sound to speakers
you need to make sure youre getting a signal from the source, RCA's I suppose. Check for loose connections or broken wires. make sure to have 12v+ on power and remote inputs at amp...proper ground too. Lastly, check your ohm loads at speakers, maybe one is about dead. make sure crossover settings are correct.
good luck!
Sep 17, 2009 | Pyle BZDBP212 Car Subwoofer
I had memory added to my pc so everything was unplugged. Now I can't figure out which one is the power source for my speaker bar and where it should be plugged. The speaker bar has the green light on and...
Make sure the green plug from the speaker bar is plugged into the green plug on the back of your computer. If it is plugged into the wrong jack you will not get sound. Hope this helps.
Mar 16, 2009 | Dell AS500 Sound Bar Computer Speakers
Front usb port does not work
Try this, it doesn't sound as it it should work but I tried it and it does.
Turn off the computer and unplug it.
While unplugged hold in the power switch for 10-15 seconds
Now restart and plug in the ipod
Jan 13, 2009 | E-Machines eMachines Desktop PC
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
Acer aspire desk top t180 has no sound
Sounds like he forgot to plug back in the sound cable when he took his iPod out. Simple fix for this. Pull out the desktop box (computer) and find what should be a green sound cable and plug it into a green port in the back of your computer. If your having trouble as to what it looks like, get your son to identify what he took out of your desktop to listen to his iPod and plug it back in. Also check that your speakers are turned on and are up on the speakers and on your desktop, which you can find in the bottom right hand corner near your desktop clock. The icon looks like a speaker and just click on it once and make sure its up all the way and not muted. Let me know if this works or not
Hope This Helps
Nov 19, 2008 | Acer Aspire™ T180 PC Desktop
Logitech mm50 speakers
if no light came from the speakers then something is corrupted inside them .. you have to check the power source and power cable of the speakers first ... if everything is fine then the speakers are corrupted from inside
Dec 28, 2007 | Logitech Inc MM50 Portable Speakers iPod...
Bose MediaMate Computer Speakers Logo
2,390 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
