Question about Cell Phones
When i click app alway says failer to load tap to refresh but then just says the same
How do i block a number on my alcatel one touch pixi 3
Block Calls & Messages:
  1. Open the apps drawer and launch "Contacts"
  2. Tap the name of the contact you want to block calls and messages from
  3. Tap "Edit" > "Menu" and enable "All calls to voicemail"
Unblock Calls & Messages:
  1. Launch "Contacts"
  2. Tap the contact you want to unblock
  4. Disable "All calls to voicemail"
Forward Calls (Unconditional):
  1. Tap "Phone" on the home screen
  2. Tap "Menu" > "Settings"
  3. Tap "Call settings" > "Call forwarding"
  4. Choose to "Always forward" and if necessary, enter the phone number to forward calls to
  5. Tap "Enable"
Forward Calls (Conditional Forwarding):
  1. Open the "Phone" app
  3. Go to "Call settings" and tap "Call forwarding"
  4. Select to forward calls "When busy", "When unanswered" or "When unreachable"
  5. Enter the phone number you want to forward calls to and tap "Update" or "Enable"
Turn Off Call Forwarding:
  1. Open "Phone" and tap "Menu"
  2. Tap "Settings" > "Call settings" > "Call forwarding"
  3. Select "Always forward", "When busy", "When unanswered" or "When unreachable"
  4. Tap "Disable"
Read more: http://cellphoneforums.net/general-cell-phone-forum/t381553-alcatel-onetouch-pixi-3-block-calls-messages%3B-forward-calls.html#ixzz4TXeusLlT
Dec 22, 2016 | Alcatel Cell Phones
Reset my w10 pro.
Step 1: Make sure Surface is shut down and plugged in. Step 2: Insert the USB recovery drive into the USB port on Surface. Step 3: Press and hold the volume-down button while you press and release the power button. Step 4: When the Surface logo appears, release the volume-down button. Step 5: When prompted, select the language and keyboard layout you want. Step 6: Tap or click Troubleshoot, tap or click Refresh your PC, then tap or click the target operating system you wish to refresh. Step 7: On the Refresh your PC screen, tap or click Next, then tap or click Refresh.
Surface restarts and the Surface logo displays while the refresh process completes (this can take several minutes).
Feb 01, 2015 | Computers & Internet
How do I reset my computer to clear it an start fresh.
Here's the answer from the Dell website:
To restore your system to its original configuration:
  1. If you have made a Dell Backup and Recovery tile, just click on that tile and go to step 5.
  2. Click on the Windows Desktop tile.
  3. Swipe from the right or move the mouse to a right-hand corner to open the Charms bar and then click Search.
  4. Click Apps and find Dell Backup and Recovery, then click on that icon.
  5. On the Dell Backup and Recovery screen, click Recovery.
  6. On the left side of the screen, click System Recovery, then click Yes, Continue and choose Factory Image from the list.
  7. Click Restart and follow the appropriate directions.
Jan 12, 2015 | Dell XPS 12-5328CRBFB 12.5-Inch...
Gateway dx4380g-uw308 keeps restarting?
Windows 8 has a neat utility that is called "Refresh Your PC". This process does not change any of your files (documents, pics, vids, music, etc.). If you upgraded your PC from Windows 8 to Windows 8.1 and your PC has a Windows 8 recovery partition, refreshing your PC will restore Windows 8. You'll need to upgrade to Windows 8.1 after the refresh has finished.
To refresh your PC
  1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings.
    (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, click Settings, and then click Change PC settings.)
  2. Tap or click Update and recovery, and then tap or click Recovery.
  3. Under Refresh your PC without affecting your files, tap or click Get started.
  4. Follow the instructions on the screen.
Aug 20, 2014 | Gateway DX4380G-UW308 Small Form Factor...
Google play won't load it always says that there: z no connection
Clear the Play Store cache. The Google Play Store app on your Android device stores some cache data on your device which could be one of the reasons why you are not able to connect to Google servers using the app and keep getting the "No connection - Retry" error message. How to fix it? Read the quick and easy steps below:
  • Go to Settings > Apps.
  • Scroll to All apps and then scroll down to "Google Play Store" app.
  • Open the app details and tap on the "Force stop" button.
  • Then, tap on the "Clear cache" button.
That's it. Now start the Google Play Store app on your phone / tablet and it should load and work absolutely fine!
Oct 13, 2013 | Computers & Internet
Play a couple hands then it freezes
when i try to buy chips theres always an error on the page that stops me buing
Feb 22, 2013 | Zynga Texas HoldEm Poker
I cant access my ninja saga it always have a lost connection. how can i connect it and play?
The Very Good Solution to that is to clear your browser's cache
if you are using chrome click in your keyboard
ctrl+ h
then Clear browsing data
then click empty cache then you will see in the upper right
past hours , past days etc.
choose the beginning of time :)
then refresh your game and it should load up perfectly :))
Aug 25, 2012 | Ninja Saga Version 2 Ninja Saga Version 3
How do i fix my sever on mini planet?
First refresh twice on facebook home then go onto me on miniplanet then refresh twice then go into world and refresh twice and it should work :D happy playing!
Mar 25, 2012 | MiniPlanet
Phone shows a balance but doesn't give me a bar code
  1. Go to the App Store and under "Updates" download the latest version of Starbucks Mobile card if you haven't already.
  2. Open up the Mobile Starbucks App.
  3. Enter your password if you have one.
  4. Touch the Balance and then click "Refresh Balance"
  5. After you have refreshed your balance, tap the circle near the middle right hand side of your screen that is flashing blue and says "Touch to Pay"
  6. Your barcode and Starbucks card number should appear.
Mar 07, 2011 | Starbucks Coffee Company Starbucks Card...
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
