Question about Car Audio & Video
My DUB2802 amp has a blue light but no green light and has no power output and fan does not work any suggestions?
  • youth_gone_w Jul 25, 2009
    i reconnected the wires after disconnecting them and the fan is on now but im still having the same problem i have a blue light on and i can hear the amp is on but still no power to my subs
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Replace fan it probably has a safety feature that will not let it start without the fan running
or it may have a thermal overload circut that keeps cutting in
Posted on Jul 25, 2009
  • jamie Jul 25, 2009
    osmedokey
    there is usualy a protection circut inside the unit somtimes there are fuses inside or just a reley for protection open the unit if off warenty and look for fusescheck them all
    failing that verify polairity and tap on all the releys 1 at a time with the unit turned on
    now hook all the speakers up to the unit and when i say verify polairity it meand plus goes to red and - goes to black or neg from the speakers in some units it a speaker is incorectly conected it will trip the protection circut especialy if all the other speakers are wired properly
    a relay looks like a box verrying in size from 1x1/2 to 4x4 inches that is
    happy hunting and good luck
    failing that take it to a local repair shop ask how much for an estament and take it from there
I am tiring to install a GE touch auto shut-off timer, I have 2 wires in the wall 1 black & 1 white, the switch has 4 wires (1 green[ground?], 1 blue, 1 black & 1 white) when I try to follow the...
You might not be able to use that switch in your configuration. It appears that the power was run to the light and only two wires were run back to the switch. The old switch only closes to connect those two wires completing the circuit at the lighting fixture, but you need a hot and a neutral to operate the electronic switch that you have.
Gary
Apr 18, 2011 | Vacuums
The wires for hooking this fan up are white,black and blue my guess is white and black are hot and blue is a ground wire. is this right?
White (Neutral) White to White
Blue (Light to Hot) Blue to Black (optional)
Black (Fan to Hot) Black to Black
Green (Ground to Ground) Green to Green
If you do not have a green lead you might see a green screw to attach the ground wire from the house power. The fan has the optional light fixture future connect the blue wire to the black hot wire. If you have the optional light fixture you may want to connect it to a separate switch power.
Jan 14, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
Flashing green light on psu
you need a new power supply and try it see if any change it try to take off your modem and one of the 2 will be a problem thanks
Nov 08, 2009 | Computers & Internet
I installed a ceiling fan with light, fan works but notthe light.
Are you sure you got the wiring correct?
Ceiling fans usually have 4 wires....a black a white a blue and a green
the black & blue wire from the fan need to be connected to the black wire the white to the white and the green to the ground
Sep 18, 2009 | Hampton Bay 52 In.Carriage House II in...
Speakercraft DBB12100 Amplifier, Circuit problem
Sounds like its a problem with over heating. open unit clean out all dust and dust bunnies wich compressed air. check that all fans are opperating. (fans on 6x100 amp units or thermal controled). If amp goes into protection prior to fans turning, there is your answer. the @ power supplies will have a green light on the output side. if the light in on power supply is good. or you can check that the output voltage is at 48Vdc on both units.
Sep 18, 2009 | SpeakerCraft DBB12100 12-Channel Amplifier
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Won't Start
BLOWN YOUR FUSE NEED NEW FUSE IN THE POWER SUPPLY
Jun 30, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Car Audio & Video Logo
103 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
