Question about Nokia IP390 (NBB0305000) Firewall
Nokia ip 390
Hello, I have an ip390. Today was short and light when lit, a light with an exclamation point in orange. What does it mean to be or where to get a manual? thanks
Exclamation light lit what does it mean
Something is wrong. Check with your manual for an explanation of what the exclamation point signifies. Could be no paper, no toner, whatever.
Aug 27, 2015 | Lexmark E234n Laser Printer
Horseshoe mean whit an exclamation point
forenza daewoo wonder car.
no year, no joy, sorry
the operators guide in the glove box answers this on all cars sold.
lost it? , suzukipitstop plus sells it. google that. $4 day pass, hint?
here is GENERIC page.
http://dashboardsymbols.com/the-symbols/
Sep 03, 2014 | Suzuki Forenza Cars & Trucks
The light on the dash is on that shows exclamation point and dashes around it ... what does it mean?
it means u have a exterior bulb out somewhere. also if u have the owners manual its located in there too.
Jul 20, 2010 | 2006 Volkswagen Jetta
Exclamation point warning light came on...what
A yellow explanation point symbol on the dashboard typically applies to the Tire Pressure Monitoring system. A thick ! inside a half drawn flat tire symbol to be complete and comes in yellow color when lit. Under normal vehicle set-up, if this indicator stays lit after the power-on selftest, you need to check your tires for any uneven pressures and adjust their pressures to correct specifications. Okay? : )
A red exclamation point inside a circle when lit indicates your parking brake is on, or your brake fluid level is low.
Jun 18, 2010 | 2008 Chevrolet Trailblazer
Blinking Orange Exclamation Point on 04 4runner
Since your question is listed as a 1999 Saturn SL and a Toyota 4Runner, I will answer both:
1999 Saturn SL
Typically the orange exclamation point dash warning light is indicating a problem with your brakes, parking or hand brake. Check to ensure that your emergency brake is completely disengaged.
Check to ensure proper brake fluid level.
Otherwise this could be indicating a problem with the ABS system.
04 Toyota 4Runner
Low tire air pressure. Inflate to approximately 32 PSI should correct your problem.
I hope this helps.
May 12, 2010 | 1999 Saturn SL
Orange exclamation point light comes on
sounds like you might be low on break fluid
Jan 10, 2010 | 2003 Ford Focus
Lights came on dashboard
I already found the owner manual on the internet. thanks for helping me out.
Jan 29, 2009 | 2000 Volvo S40
HP 7410 - No display and orange exclamation point is lit
Unplug your power supply and leave it off for like ten minutes, then replug it and see if it will initiate itself, if not it sounds like serious malfunction.
Aug 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Nokia IP390 (NBB0305000) Firewall Logo
132 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
