Question about Pool & Spa
I have a Flo Master Xp2 spa pump 2 HP two speed and when hooked up it turns the controller power off. Unhook it and the power is good. It doesn't trip the breakers do I need new pump?
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: I have a flo master xp2 / 48 frame / 230V / 2.5 hp
You shorted the 230 lines at the motor terminal board. If you are certain you have reset any and all breakers feeding the spa and that the 230V is getting back to the pump motor then you blew the winding leads as you shorted the motor. While it is possible a motor shop could repair the leads it is far more likely the damage caused will cause the price to be that or more of a replacement motor.
John
Posted on Sep 21, 2010
adamh294
  • 310 Answers
SOURCE: My Spa needs a new pump. A Max E Pro Pump 2 speed
Yes, and I recommend and install them. Look at the voltage and Amperage information on both as well. It is typical to see 220V @ 12.9 amps. If you find this on both motors, they are the same size anyways.
It would take a while to explain, but motor manufacturers can rate a motor @ 1.5HP or 2HP and it can be the same motor. They use a rating called a "service factor" to screw around with the actual HP of a motor. But even if the 1.5 is a 1.5, it would be sufficient.
Posted on Jan 11, 2011
Testimonial: "This is very helpful but I just was told that because I have an in the ground hot tub the Aquaflo would not work. It needs an outflow? Please comment"
adamh294
  • 310 Answers
SOURCE: I was told that the Aqua Flo Master Xp2 Spa pump
I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Posted on Jan 13, 2011
Testimonial: "Thank you so much. That helps alot. Do you have any other suggestions for a pump tha might be less expensive then a Max E Pro?"
Have a 2 hp 2 speed Pentair whisperflow pool pump, it seems to only operate in low speed.. is about 5 years old..checked for obstruction at impeller but seems fine..any suggestions much appreciated..
check for power on high with a meter, or bring it to your local pool pump motor repair guy with free testing. TAKE NOTE on where the wires are hooked up !! they must go back the way they came off !!!
Sep 29, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My flo-Master XP2 06620397-2 has large leak when the jets are turned on. Do I need a new one or can the leak be repaired?
sounds like you need a new seal kit if it is leaking between the plastic pump housing and the motor. this seal kit is a model PS-200 and will run you about $30
US Parts Center
Aug 23, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I was told that the Aqua Flo Master Xp2 Spa pump 1.5 hp 2 speed pump was the equivalent to the Sta rite Max E Pro 2 speed pump but then from another source was told that the Aqua Flo was not made for in...
Jan 12, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I am looking for a Flo-Master XP2 by Aqua Flo. Modal 06630397-2. How much would it be?
A quick google search brings up a number of online sites between $340, and $430
Sep 22, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I have a flo master xp2 / 48 frame / 230V / 2.5 hp / 2 speed spa pump. I accidentally hooked switched the high and common lines when wiring the electricity. The low line was done correctly, because they...
John
Sep 21, 2010 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
