Question about Coleman Air Tools & Compressors
Find author reed farrel coleman - Coleman Air Tools & Compressors
    Top Expert:
  • Coleman Master
  • 76,109 Answers
SORRY BUT - You are on the wrong website for this type of inquiry. This is a community based self-help website for the repair and use of manufactured products made for consumer use..
Posted on Jul 10, 2017
2 Suggested Answers
  • 1383 Answers
SOURCE: coleman compressor no build up of pressure
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
Posted on Jan 10, 2009
Will a blown head gasket on my Coleman powermate 5000 er stop it from running?
It may run for awhile in this condition, but eventually it will stop running and be completely ruined. I WOULD NOT RUN THIS WITH A BLOWN HEAD GASKET! My advice is to either find a replacement part, a manual and fix it, or find an authorized repair shop and have them fix it.
Mar 16, 2016 | Coleman Powermate Powermate 5000W...
Have a 1996 coleman black max 6hp air compressor, need reed valve assy.
You might try some small engine repair shops for that part.
Jun 04, 2014 | Work Safety
Takes a long time to fill up
A reed valve or check valve may be broken or damaged. Replace both reeds if one is cracked or broken.
Feb 14, 2012 | Coleman Powermate 60 Gallon Air Compressor
Take about 30 min to fill tank is this normal?
No. Normal would be one or two minutes. Either your piston is not sealing well, or the reed valve that acts as a one-way air ratchet is not sealing well. If it looses pressure while sitting idle, it's the reed valve.
Apr 13, 2011 | Coleman Powermate 27 Gallon Air Compressor
The motor is running. Belts and pulleys are turing. oil level is good. No leaking from tank or conectionslbs. Motor runs contiuously tank Air pressure will not rise above 25-50.
While the compressor is running and has reached point of not attaining higher pressure remove air filter and place your gloved finger over the intake hole (be carefull may be hot). If compressor is working properly you will feel suction, if however you feel air blowing out of intake most likely blown head gasket /s and or broken reed valves. Easy to fix however, look for parts at mastertoolparts.com
Nov 03, 2010 | Coleman 6.5hp - 80 Gallon Vertical ASME...
I have a 5 HP Coleman air compressor. I was using it to provide air to my plasma cutter which requires 60 psi to operate. Basically, air compressor's motor keeps running, but it's stopped creating air...
You did not list model number, however if you have oilless type check the cylinder/piston by manually turning crank until piston is at top and examine cylinder for wear or scratches. If worn replace cylinder kit for full pressure. If ok check reed valves /valve plate for wear or broken reeds. If oil bath type, problem is usually air leak or reed valves / valve plate. As a general rule, you can keep track of wear by noting how many minutes it takes to fill the tank to cut-out. As the compressor wears it will take increasingly longer to fill. When new, and depending on tank size/ hp, most compessors fill within 2 ~ 5 min. Good luck
Sep 24, 2010 | Coleman Air Tools & Compressors
Does anyone know the correct placement for clutch cable on a 2004 FLHT?
From farrel at the handle in front of the bars,down left front frame down tube,under regulator to clutch. No binding or restriction is key
Mar 11, 2010 | 2004 Harley Davidson FLHTCUI Electra Glide...
Air pressure iI gone but motor works haappened all
As I understand it, your air compressor motor runs but you can not build pressure. Is this correct?
Two main reasons:
#1: Your safety valve popped and the air is going straight out the safety valve. You should be hearing a loud hissing noise if this is the case. Press the safety valve back in and you should build pressure. Many such valves have a ring on them (to help you find them). It should be very near the pressure switch.
#2: You have a broken reed valve. A reed valve opens or closes based on the pressure it is under. It allows air to enter the tank on the compression stroke, but will not let it out of the tank as the piston strokes up and down. If it is broken or stuck open, you cannot build pressure.
and #3, a after thought, no extra charge ;-) The rings on the piston may have broken.
For #2 and #3, it will be necessary for you to remove the head to inspect.
Find repair parts at the Coleman web site.
I hope this helps you solve your trouble.
Thanks for your question at FixYa.com
If you found this helpful, please vote.
Thanks
Dec 24, 2009 | Coleman Powermate 4 Gallon Air Compressor
Coleman compressor no build up of pressure
Jan 10, 2009 | Coleman Powermate 27 Gallon Air Compressor
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
Oct 28, 2008 | Coleman Powermate 02 - Gallon Air...
Air Tools & Compressors Logo
521 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
