On the Woble top loader where are the revs shown so as to use a lower rev to have crease free wash
ollie reece
  • 1167 Answers
SOURCE: WILL NOT REV
hi mate it sounds mechanical side instead of electrical have you changed the air filter or cleaned it also check to make sure the oil and petrol are being mixed correctly and check the air screw on the carb is the right amount off turns out if its incorrect it will either be to rich or to lean it normally says the amount of turns in the manual also check to make sure the jets are clear and the reed valve is closing propally many thanks
Posted on Apr 03, 2009
jmgldsmth
  • 1889 Answers
SOURCE: revs keep raising and lowering
place a vacuum guage on the intake and, look for a cracked vacuum line
Posted on Apr 21, 2009
  • 32 Answers
SOURCE: temp stuck on hot on my front loader washing machone
Water temperature is controlled by a switch which activates or deactivates the hot and cold water solenoids. Replace this switch, it is not expensive.
Posted on Apr 22, 2009
moretons
  • 155 Answers
SOURCE: Hunting at top revs and dies under load then takes
Sounds like you need to clean out the carby and flush the fuel tank out
Posted on Aug 12, 2009
  • 87 Answers
SOURCE: yamaha xt 600e 1995. won't rev above 4000 under
sounds like it may be running out of gas under aload it might be carb trouble
Posted on Jul 29, 2010
Why are my business shirts on a gentle cycle or any wash cycle so badly tangled togther?
Hi Stella,
I suspect the tangled shirts coming out of the washer is a result of the differences between the way a front loader vs a top loader clean clothes and can not be avoided. I don't think this is the source of the wrinkles though. I suspect the wrinkles are more a result of how long clothes remain in the dryer *after* the cycle has completed. If you remove the clothes *promptly* from the dryer and use a "dryer sheet" you will reduce / minimize the wrinkling you're seeing.
Mar 28, 2015 | Washing Machines
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
Speed of the lawn mower governor is missadjusted
The engine revs are turned down to make the machine noise compliant, increasing the revs will greatly increase the noise, the engine revs shouold not realy be increased, however a dealer with a suitable engine taco may do it for you, it is very important not too over speed the engine or it will self destruct,
Apr 11, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Agitator is slipping on wash cycle every thing else is working fine where should I look for the problem. Machine is Maytag Performa PAV3200AAW Rev 12
If the drive belt is worn or loose, that could cause your problem.
drive belt is on the bottom of top loader
and behind front loader.
Nov 14, 2012 | Maytag Washing Machines
Top loader does not spin fast enough to spin dry.
possibly the clutch is slipping, i've heard you can take a #10 washer and put it in one end of your clutch spring caps and that would tighten it up
Mar 23, 2010 | Kenmore Washing Machines
How fast can you ride the m50 w/o over reving the
Motorcycles and cars are designed so you can't over rev the engines in high gear. Air resistance will keep your speed low enough so the engine can't over rev. However, in a lower gear, you CAN over rev. If you don't have a tachometer on the bike, read your owners manual for suggested top speed in each gear. Or do a Google search for your bike and and "speed" and "gear".
Sep 07, 2009 | 2005 Suzuki Boulevard M50
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
