Codes for Kogan LCD tv Model - 463D1A remote control
    Top Expert:
  • Televison & ... Master
  • 75,476 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Posted on May 02, 2017
  • 518 Answers
SOURCE: remote control codes for naxa tv model nx -524
You neglected to post the Remote's Make and Model. However, most Univ. remotes allow you to "Scan" the TV codes one at a time. You would do this and watch for the TV to turn off. when it does, you have the code and can store it.
Geno
Posted on Mar 05, 2008
1Guru
  • 61 Answers
SOURCE: codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Posted on Dec 14, 2008
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
pabloloco
  • 2335 Answers
SOURCE: codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Posted on Oct 16, 2009
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
I have a sansai universal control and I need a code for a Kogan tv
Use code search on your Sansui URC to fond something controls your Kogan TV. If a search through all codes contained in the URC fails, you may have to try another one . All URCs do not contain all possible codes.
May 28, 2018 | Universal Televison & Video
Hi i have a skandia bw600 remote 6in1 and need codes for KOGAN TV please help
1:Press and Hold the SET key followed by the desired Device Mode key(e.g. TV ), the LED indicator will light up.
2:Release both keys..
3:Use the number keys to enter your 4-digital Device Code, the
indicator should go out immediately.
but no kogan code
Jun 22, 2016 | Televison & Video
What is the code to allow my bt youview controller to also control my Kogan tv model no KULED24DVDAD
0382,0339. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
Jan 23, 2015 | Televison & Video
Kogan TV remotes
What about them? Where to get them? This has caused much angst online, with some people saying Kogan is unresponsive.
The Logitech Harmony remotes will operate a Kogan, and you have the choice of a range of models. I have used one on a LG TV and it worked OK, but some buttons became mushy after about 2 yrs.
Aug 07, 2014 | Televison & Video
WHICH UNIVERSAL REMOTE CAN USE FOR THE KOGAN HD TV?
Try procedure to program remote without code.. Look manual how to do it, it's different doe each remote
Jul 05, 2014 | One For All URC-3021 Remote Control
Digitech Universal Remote to a Kogan TV
try google and find out who made.
Apr 18, 2014 | Televison & Video
Kogan tv code for control by Bose Lifestyle 48 remote control
The Bose remote control have no set-up codes to synchronize with Kogan TV. If you wish to get more codes and other details. It has setup code list, and setup procedure to many popular brand remote controls. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. If you wish to get more details about this, try the sites linked here.
Jan 01, 2014 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
