I got a laptop from a friend and it came with a dlink routher and card well we ordered att high speed internet and how do i connect to att with my dlink card and router and have a modem that att sent me and it has ethernet connection but laptop doesn't, PLEASE HELP!!!
  • 103 Answers
Hook your ethernet into the wireless router input (should be labeled with green around it or some other color) then that will activate the router and you should be able to access the internet via wireless
Posted on Jul 25, 2009
What is this DLink Express Ethernetwork card for??
hi nadeemsultan
this works exactly as like a built in LAN adapter to your laptop. You may use this as a backup for your built in laptop LAN adapter. Altough this is more useful for some IT professionals who sometimes require a two LAN setup. I have also attached a useful guide that if found on the product catalogue itself.
WHAT THIS PRODUCT DOES
Connect to your wired home network by adding a D-Link 10/100 Fast Ethernet Notebook Adapter to your notebook computer. Once connected, you can access shared documents, music, and photos from other computers in your network. If your network has a high-speed Internet connection, you can also check e-mail, browse the web, and chat with friends and family online.
hope this helps. please let me know.
janc30
Feb 16, 2011 | D-Link Express EtherNetwork DFE-690TXD...
I have ATT internet service using a USB device( no DSL or cable wires/lines, just plug in the USB into the port, that's it). I also have a wireless printer that is setup with a DLink router. When I print...
In order for you to print on that particular printer, your computer and the printer need to be on the same network. That is the only way it will work. So, either connect your computer to that Dlink router or connect your printer directly to your computer and browse internet from USB ATT.
Hope this helps.
Aug 11, 2010 | Computers & Internet
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
How do I intall the dlink router if I dont have a cd drive My computer is a dell inspirion and is runs on vista
hello, here is what you need to do: if have a pc connected to high speed modem directly you will unplug the network cable from the back of your pc/laptop and that end will then go in to "WAN" port on the new dlink router.
second, you take another wire and plug one end in your pc/laptop and the other end in one of the 4 lan ports in the back of your new dlink.
restart everything in the following order at 30 seconds duration:- first the cable/DSl modem, then dlink, then your pc/laptop.
once everything is up open up internet browser and test connectivity.
at this point you should have internet up and running but you need to configure you router and wireless etc.
from your browser in address bar type in http://192.168.0.1 and hit enter that will bring you router login prompt : default user name is "admin" and password is left blank and hit enter, you are now in router to configure options as you please.
I would strongly recommend changing your router password administration and if you plan on using wireless, setup SSID, encryption, network key on wireless. NEVER LEAVE IT OPEN.
Hope this helps
let me know if you have any questions
Amar Sondhi
Dec 04, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
The dlink will not connect to internet because it says the usb port is not high speed how do i fix this
i think your usb slot supports only version 1.1 Install a new external usb 2.0 card or higher.
USB versions and speed rates are as follows:
USB 1.0/1.1 - 1.5 Mbit/s (Low-Speed) and 12 Mbit/s (Full-Speed)
USB 2.0 - 480 Mbit/s (now called Hi-Speed)
USB 3.0 - 4.8 Gbit/s (SuperSpeed)
Nov 13, 2009 | Computers & Internet
Internet connection keeps dropping
is there any alternative on how to operate and install by our own
Nov 12, 2009 | Computers & Internet
My internet won't go wireless
routher cable must be connected to the Internet, then connect the cable routher - pc and run your browser in order to configure the connection. check that you have enabled wifi, save the settings and check if it works. Make sure that your ISP does not grant the Internet through the network adapter MAC address, in which case you will need to change your MAC address on the routhera which you used previously.
Sep 09, 2009 | Linksys Wireless-G Broadband Router
Sharing internet from dlink 510g to linksys wap54g AP
yes, the manufacturer doesn't really matter as long as they are 802.11g (usually backwards compatible with a and b) so as long as the router and the adapters are installed properly NO problem
May 14, 2009 | D-Link High-Speed 802.11g Wireless PCI...
No internet access with air card
Before you go to your friend's, download the Watcher program from Sierra wireless onto a cd. And install it instead of the AT&T Connection MGR.
For random disconnects and difficulties signing on with ATT Communications Manager
download the watcher program @
http://www.sierrawireless.com/support/
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 29, 2008 | Sierra Wireless Aircard 860 PC Card...
I cannot get high speed internet service from att because my network adapter is not compatabile with att
get a new network adapter
lol
or get an att compatable laptop card. nip into any tecky shop like pc world they will sort one out for you.
noptsure how much they would be though.
regarda
matt
Aug 21, 2008 | Gateway Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
