Question about Kenmore Washing Machines
My front load kenmore washer will not let us choose a temperature. No light indicators light up
SOURCE: Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Posted on Nov 02, 2007
  • 1073 Answers
SOURCE: kenmore front load washer
bad door lock switch
Posted on Apr 11, 2008
  • 1073 Answers
SOURCE: the washer mode light keeps blinking
the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
Posted on Apr 16, 2008
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
SOURCE: No manual for Gorenje front loading washer.
Here is a link to the Gorenje website, you can download the manuals from there which explain all the symbols. This link is for the WA50140 machine which I have, just click on the 'manuals' tab
http://www.gorenje.co.uk/laundry/washing_machines?c=161105
Posted on Apr 28, 2009
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
What does error code f5 mean?
The F5 error code indicates a water temperature problem. The control board circuit is not recognizing a resistance change in the water temperature sensor.
You most likely have a loose connection at the tub sensor , or a bad heater.
Read more: http://forum.appliancepartspros.com/washer-repair/244131-error-code-f5-model-11045087404-kenmore-elite-residential-washer.html#ixzz34ySdUUeZ
Jun 14, 2014 | Kenmore HE2 Plus Front Load Washer
Getting an F35 error message on a front loading kenmore washer. Any suggestions?
This link should help:
http://www.managemylife.com/mmh/questions/123674-does-f35-error-code-indicate-kenmore-front-load-washers
May 20, 2011 | Kenmore Front Load Washer
Code F 24 what does it mean The washer dose not allow me to do anything when I push start. All the areas light up and flash with code F 24
The F24 error code indicates a problem with the water temperature sensor. code meanings should be under lower cover, remove panal.
Jul 13, 2010 | Kenmore HE2 Plus Front Load Washer
What does the code F24 mean for a kenmore front load washer mean?
The F-24 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This is usually caused by a failed temperature sensor (Key 24 in the image below). A wiring failure or a failed electronic control board could also cause this fault code
If you are able to unplug the washer and safely remove the bottom front service panel, then you can check the resistance of this temperature sensor using a volt/ohm meter. To remove the bottom front service panel, take out the screws at the very bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, you should be able to pull the wires off of the temperature sensor at the bottom front of the washer tub. Measure the resistance across the leads of the temperature sensor. You should measure about 10K ohms (10,000 ohms) of resistance at room temperature. A reading that is more than 30% off would verify a failure in this component. Replacing the temperature sensor would fix this type of problem.
Oct 22, 2009 | Kenmore Washing Machines
My kenmore he frnt load washer has an error code of (f24). tried the manual solution no luck. can you help me?
On this model of HE washer, the F24 code indicates that the water temperature sensor is out of range (23 degrees to 217 degrees F). This usually indicates a bad thermistor (temperature sensor - Key 24 in the image below). A bad wiring connection or a failed control board could also cause this problem.
Good luck
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code on kenmore washer
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
The indicator lights that surrond the dial are flashing on my Kenmore 110.46462501 front loading washer.
Unplug and wait 40 minutes to reset the ECU and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 46462 Front Load Washer
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
