Question about The Office Equipment & Supplies
My citizen 3550 prints with a line through the numbers, is there a way to fix this?
  • The Master
  • 2,045 Answers
Try to clean cartridges from the service menu
Posted on May 02, 2017
3 Suggested Answers
SOURCE: Citizen iDp 3550 prints double-spaced
It is a dip switch setting, on dip switch #6, it needs to be "On" It will then single space the lines. After re-setting the switch under the cover, turn off the printer for 30 seconds to clear the buffer...then holding the "LF" button, turn it back on, until its self test is complete. You problem will be over.
Posted on Feb 06, 2008
SOURCE: i have a citizen 3550
Try generic text only driver from windows it should work
Posted on Aug 03, 2012
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
Printer double spaces between lines
That is a setting in your printer setup menu under options or advanced. Page set up should come up under advanced or as its own tab.
Apr 09, 2014 | Citizen iDP-3550 Matrix Printer
I have a citizen 3550 printer how can i hook it up to my computer to print out misc. things instead of using you conventional printer?
Thank you for posting to Fixya.com and it is my pleasure to guide you.
To help you in the furture I have found the manual for reference. Click the link or copy paste it to download it. http://www.posguys.com/download/iDP3550UME_09E.pdf
From the manual for the Interface Cables, the manual has pictures.
4.2 Connecting the Interface Cable
1. Turn off the power. (Mating side included)
2. Check the top and bottom of the cable terminals, and connect to the interface connector.
3. Secure the cable terminals.
Serial interface: Tighten screws to secure.
Parallel interface : Turn clamps to secure.
4. Connect the interface cable to the computer.
4.3 Connecting the Drawer Kick-Out Connector
2. Check the top and bottom of the drawer kick-out cable connector and connect it to the drawer kick-out connector located at the lower section of the printer.
3. Screw the grounding cable of the drawer to the grounding terminal located at the lower section of the printer.
CAUTION: • Connect only the prescribed drawer (Solenoid) to the drawer kick -out connector.
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
Jun 21, 2011 | Citizen iDP-3550 Matrix Printer
Printer is printing jibberish = looks like a lot of "f"s underlined.
Try to turn the printer off and then on again. If that does not clear it you need to re-install the driver, the driver may be corrupt.
Nov 16, 2010 | Citizen iDP-3550 Matrix Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
My printer hp deskjet 3550 not working properly
my printer did not take the printing job. I wnt to cancel the job but it is not cancell lsat one job is still pending. If acctionally take the print firt two line is printing the rest of the matter is pending and that job is not able to cancel . I have hp diagnostic utility but it is also not working to release the printing que. kindly do needful to solve this problem
Jun 21, 2009 | HP DeskJet 3550 InkJet Printer
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
Jan 14, 2008 | Citizen 3550 Matrix Printer
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
