Question about Kenmore Refrigerators
Kenmore Elite model 795 beeps every 30 seconds. Interior is cold. Why?
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
  • 62 Answers
SOURCE: Kenmore Elite Bottom Freezer Mod. #795 75544401
The unit was built bt LG. It is a computer controled unit and the timer is built into the main control board on back of the unit. However, the most likely cause of the broblem is the defrost terminator located on the evap on the upper right hand corner. Also, try unpugging the unit it will reset the computer board. You will also have to defrost the unit.
Posted on Aug 30, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Owners manual for Kenmore Elite Microwave Model 66462
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgcaab351.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Posted on Jan 18, 2009
  • 49 Answers
SOURCE: my kenmore elite calypso keeps beeping Fl what
FL (flood condition) also can be an indicator of a bad pump. The washer tries to drain and cannot because the pump has failed or is jammed with debris.
You can run a complete washer diagnostic procedure to see if you can isolate the fault by doing the following. I recommend you make sure the room is quiet so you can hear the pump motor running when expected, as well as the main drive that nutates and spins.
Perform a "key dance" to put the washer in the diagnostic mode by pressing the Prewash Options button, Wash Time, Prewash Options, Wash Time - each 2 times in rapid succession within 5 seconds total. The display will change to 99 and begin counting down (in seconds) as it runs the following tests. Listen for the pump motor to actually run and not just "hum", indicating a jam or burnout.
Display 99-81, Nutate & fill
Display 80-61, Nutate & recirculate
Display 60-41, Nutate, Fill & drain **
Display 40-21, Nutate, Fill & drain **
Display 20-0, Spin & drain **
You can cancel the test in progress at any time by pressing the Stop/Cancel button.
**during these phases the pump will run forwards and backwards (recirculate & drain). If you do not hear water pumping inside the washer or draining out the drain, your pump is likely bad and needs to be replaced.
The old style pump was a two-part assembly and the re-engineered part # mentioned above is a single piece that solves the impeller failure problem the original pumps were prone to have.
www.pcappliancerepair.com sells replacement pump part # 285990 for this washer and they are a reliable supplier with a good value. You can purchase a lifetime warranty on the pump from them for an extra fee.
Unfortunately there is not enough room in this text box to post the pump removal & replacement procedure but you can get your local handyman to do the work for you if you are not inclined, as I was, to drain the washer and turn it on its side to figure out how to replace the pump.
The other problem is that once you start getting a pump failure you need to look at the root cause. If the pump was ruined by draw strings or debris being sucked into the pump impeller, it is time to replace the top wash plate assembly (the plastic plate inside the washer that the clothes sit on).
There is a rubber seal on the outside edge of this plate which wears out over time and rotates upward, opening a bigger gap between the plate and the stainless steel drum which lets draw strings and other things get sucked all the way down into the pump. The upper wash plate & seal is a single unit and the seal itself cannot be replaced as it is molded into the plastic piece. Order this from Sears to insure a more recent 'cure date' on the rubber seal from the manufacturer, rather than 3rd party suppliers who might stock the part for longer periods and have old rubber seals past their cure date. The wash plate should be replaced about every other year.
Posted on Oct 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: I am getting an ER
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&#%#
Posted on Sep 25, 2010
I have a Kenmore Elite model number 795 - 7105 how do you change the temperature in the refrigerator to go up and down
Check this link out: http://www.manualslib.com/manual/85627/Kenmore-Elite-795-7105.html?page=18&term=temperature&selected=3
Oct 21, 2015 | Kenmore Refrigerators
What is the lifespan of a Kenmore Elite Model 795?
Free Kenmore Refrigerator User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Kenmore > Kitchen Appliance Kenmore Products 1 - 50 of 357 - Kenmore Refrigerator User Manual.
Jul 19, 2015 | Kenmore Refrigerators
Have Kenmore elite 795 710 63010, need to replace Funnel assy but need to R & R the LCD/LED panel
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-elite-Parts/All-Products-Parts/ADW73149901/0046/795/Model-79571053010/0583/0161000?keySuffixId=&pathTaken=partSearch&pathRender=modelComponent&documentCompId=F1003026&diagramPageId=00006
Oct 22, 2014 | Refrigerators
Kenmore 795 continually blowing cold air into frig
If the control will not change and the lock is lit, first try unlocking it. Press and hold the lock tab for 3 seconds. If nothing happens, try unplugging the power cord for 30 seconds and reconnect it. This will reset the board.
Nov 02, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore elite model 795 leaks water on the floor - it appears to be coming from the front left corner. any advice?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 07, 2011 | Refrigerators
Ice buildup Model 795-78402-802 Kenmore SN:
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Apr 29, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite model number 795. my ice dispencer only gives crushed ice even though its set to cube
1st i would remove all ice out of bin, clean outBIN with warm water under sink. put ice back in do not throw away for testing purposes. if worked then a cube may have been caught in bucket chopper improperly . if didnt change anything could be a bad crusher solenoid. in home service could run you 90-145 dollars depending where you live. if you do it yourself crusher dispenser solenoid will run about 30-50 DOLLARS. hope this helps
Sep 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Interior Lights "ON" With Doors Closed
If you have a Sears model with the model number beginning with 795 the unit was built bt LG. You can check with LG. However, if you have the problem with the interior light staying on, LG and Sears will honor that problem as a warranty call going back 3 years. No cost to you. call Sears and arrange the call.
Aug 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
